Get Jacked
slowmachine
New Hampshire
I wouldn't know. I've seen Deuces stuck, and I've seen 5-tons stuck, but I've never seen an MTVR stuck- it's got 53" tall tires, dual CTIS, and FIVE drivetrain lockers...
Springtime in the Arabian desert brings heavy rain (even grass that supports sheep grazing, to my surprise) and the ground can be saturated many feet below the surface. At the surface, the sun creates a dry crust that can be only inches thick. It was like a train wreck, running in slow motion, but stupidly moving forward nonetheless. You could see a wave of the surface crust building up in front of the truck, and us bystanders were screaming and waving to the driver to keep going. Unfortunately, he stopped, and all six wheels broke through the surface crust, at which point he gave it full throttle and buried the truck to the frame. It took a wrecker and another MTVR, end-to-end, to slowly drag the stuck vehicle forward, tires spinning, until it reached something solid below the surface and gained some traction. I've never seen mud like that before or since. It was like thick drywall compound.
GregsFX2Ranger
Greg
2021 XLT 302A 4x2 Rapid Red Black Appear Package
Management
This was in a Youtube video from a Truck Manufacturer! LOL
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
Running something similar to this. Mine is a Torin (brand).
https://www.amazon.com/Alltrade-Pow...words=Bottle+Jack+tall&qid=1617798162&sr=8-15
I would imagine they all come out of the same factory and get branded and painted differently. Even though you probably won't ever need the capacity of a 6-Ton Jack, it is a little taller than most 2-Ton or 4-Ton jacks. I think the assumption is that bigger trucks are taller trucks.
Edit to add - I found the one I use. Works Great.
https://www.amazon.com/BIG-RED-TAM9...words=Torin+Bottle+Jack&qid=1617798431&sr=8-4
I've been looking into getting a bottle jack to keep onboard instead of using the scissor jack. I was worried it wouldn't get the truck high enough and I also want it for the Bronco which will have 33's and possibly 35's if I get the Sasquatch package.
I found this site where you can buy extensions for bottle jacks along with jack pads so you have a safer area to jack from. Now they're not cheap but they look to be very good quality and you can buy these individually or as a set. I linked the whole set but you can click on each one and there's usually a video to show you how they work.
https://safejacks.com/products/safe-jack-bottle-jack-recovery-kit-without-bottle-jack
CO2Ranger
This was going to be my question. The bottle jack looks like it'd be sketchy to get on the rear axle safely. I'd use jack stands once I had it up but would be afraid of it sliding off the bottle jack on the way up.
Same here that's why I was searching and found this site. The reviews are good and I like that you can just buy what you need. Looks like a safer way to at least get the truck up in the air until you can get a jack stand under it. I don't want to lug around a heavy floor jack all the time either.
I have this in my truck...bottle jack + stand + jack stand all in one...
I saw these before and almost bought it but there's have been a lot of bad reviews on them lately. I just didn't want to chance having an issue with it.
MoldyTaco
Steven
Salt Lake City, UT
2020 Ford Ranger XLT
College Professor
Lately? Hope it's a bad batch...I got mine in 19...
More than likely it was....You're still alive so I think you're safe. ?
ryyck
Charlotte NC
+1 This is what I carry in a tote with all my other gear in the truck bed. I've used it on uneven forest trails to change a tire, and have used it with 2.5" OEM lift and 33" tires. I thought about going bottle jack, but then I'd need a plate underneath for uneven terrain. This solves that problem, at least for me.
Dam...I'm so glad to be old and stay on hard road!!!
I haven't used it yet...maybe I'll will...drove like a million miles in my MINI Cooper and never had a flat...
MoldyTaco
Steven
Salt Lake City, UT
College Professor
