fumoto plug
Langwilliams
Langley
Lorain, Ohio
The Valvomax comes with a drain tube. Used it several times.....clear tube drains right into the container without removing the skid plate. Here's a glimpse of the drain valve......on their website too!
That looks harder to screw into the fitting with the skid plate blocking your view.
Conman50
Conrad
2019 Ford Ranger; 2014 Ford Fusion
Is the only model that will fit be the SX valve? I want the one with the long nipple but not sure how it will install without hitting the oil pan
Because of the indent on the pan, the F-107SX is the only one that will fit right out of the box.
If you want the long nipple valve you have to use one of the extensions from Fumoto. Extension will bring the mounting further out so the long nipple will screw on.
