Front wheels don't spin free when jacked up
Dereku
Chicagoland Area
If its an open diff then something is amiss here. Jack up the whole front and and try again. A limited slip will act differently.
Whiplash
Kern
The southwest Missouri Ozarks
2021 Ranger XLT FX4 / 2004 Mazda RX8
I'm new to the Tremor and really like it so far. I have a question I can't seem to find the answer to. I was rotating my tires today and noticed the front tires are really hard to spin when jacked up. I'm coming from a solid axel on a 3/4 ton truck so it doesn't feel right to me. Is this normal with CV joints or should I be looking for something? It only has about 31k miles.
My 2021 XLT FX4 has been the same.....
In park , one front tire still on ground,...
It's not hard to spin, but dosen't spin freely.
It's been like that first time I removed a wheel with 440 miles , to upgrade , and level my front with new Coilovers and UCA's....It was the same before and after the swap,,,thought like you that an open diff would spin freely.....When I did the other side it had the exact spin resistance
I assumed it was normal for a 4x4 Ford Ranger...Still the same now , had the wheels off doing rotation at 10k miles a couple weeks ago....
MyBlueRanger
Woody
Sierra Vista AZ
2021 Ranger Tremor
Contractor
I'm guessing it's a limited slip diff in front that's creating what I'm feeling. When I can get back to it I'll jack up the entire front end and see how it reacts. Thanks for all the suggestions!
Does it roll freely, like if you are on just a slight incline and put it in neutral?
Stevedbvik1
2022 Ranger Tremor XLT
If it has a limited slip diff then a previous owner would have installed it because otherwise it’s an open diff from the factory. Anyway to get the history from the previous owner?
Rp930
Denver
It is normal. You are turning the differential gears and front driveshaft. It is not a limited slip differential or at least highly unlikely. It was not factory installed.
Dereku
Chicagoland Area
Should still spin freely. Especially the front right. Only the left one would directly rotate the pinion and have the drag on it. Right on is just a few spider gears. Or vice versa, but ford was almost always front left powered.
Rp930
Denver
Maybe you should study this. That is not how it works.
Not sure what you are talking about "front left powered"? Both axles will drive the carrier through the spider gears. If both wheels are off the ground the opposite one will go the opposite direction of the one being turned. If the opposite wheel is on the ground, you will be back driving the pinion shaft and the front output of the transfer case at twice the normal ratio,⁹ therefore more resistance. Our trucks do not have locking wheel hubs so the whole front drive train is always running, so the front wheels will never freewheel.
Oh yes, our trucks do not come with factory limited slip front Differentials, only open.
Dereku
Chicagoland Area
Its the whole one wheel peel concept. Open rear diff will burn the right rear tire only if doing a burn out. When you are wheeling with 2 open diffs the rear right spins and front left spins. That is why your front right should spin more freely than the left. Typically with locking hubs they would spin equally well on both sides.
Dereku
Chicagoland Area
These videos are only valid on flat smooth ground. Not with one tire off the ground. I have rebuilt plenty of axles in my day, I get the concept. Maybe you should understand that in an open diff only one wheel gets power when faced with a lack of grip or resistance. Those spider gear just spin. But its ok you wanted to show me videos to prove how intelligent you are. I was trying to help a member out.
Rp930
Denver
Whatever you say. The Left front does not ”directly rotate the pinion”. You do not understand the how a differential works no matter how many “axles” you have rebuilt in your day. The videos are valid no matter what surface you are on. There is only one way a differential works. But hey, good luck. You seem to be the expert.
Bsthroop
Brian
New Mexico
2019 Lariat 4x2 Sport
Broadband/ Microwave Engineer
Either axle will spin the pinion when the other is on the ground. It will either spin the pinion with the other on the ground, or if not on the ground will spin the other the opposite direction without spinning the pinion and drive shaft.
Would be a good time for Dr Phil @P. A. Schilke to chime in before civil war begins ? ...
The one wheel burnout with an open differential has more to do with which wheel has the most traction, or should I say the least. It has nothing to do with the mechanical internals. Most modern vehicles now use the ABS to brake the spinning wheel and stop the wheel spin.
