Front axle grease question
Inklesstako
Oren
Hi
Xlt
Getting ready to change my driver front axle, due to the CV boot tearing. My question to anyone is what grease is used on the splined end of the axle prior to reinstalling?
Does not require any and really, you do not want any, as grease will create a (hyd lock) when trying to engage the circlip.
They generally ship with a light protective coating of oil anyway
Inklesstako
Oren
Hi
Xlt
Thank you. 🙏 my local ford dealer doesn’t return my calls.
If you want to lubricate it, use a dry lube of sorts
seasprite
Missouri
2022 Ranger XL STX
My front drive shaft was replaced at Ford for a small pin hole in the boot. The grease was being slung across the undercarriage in a nice little line. Point being there is a lot more grease in there than you realize. I'll look and see if I have pics and update this thread or post if I find them.
Wrong grease sir. The OP is talking about the end spline going into the hub.
