FORScan Modifications
spike36ff
Pennsylvania
2019 Ford Ranger Lariat
Added the frost telltale and it seemed to make my clock on dash disappear. I just have four little dashes?? Do you think this releated?
I added that a while back and it works fine. Seems to come on when the temp is under 39 or 40. I've had no issues with my clock after making the change.
spike36ff
Pennsylvania
Ive had the clock disappear a couple times after forscan mods, Go into the sync screen and set or reset time there and it will come back.
When you say sync screen you mean in the settings on the radio right?
Hambone437
ā€˜19 Ranger Lariat 4x4 Magnetic Gray / 2020 Explorer Limited RWD Magnetic Gray
Yes, that’s what I found I need to do to bring the time display back.
Andy
Andy
Anyone know if we can lower the minimum speed on trail control? From 1 MPH to .5 MPH?
I’ll ask the tuner as well. Not sure if it’s possible.
I believe 0.5 is only available in low range. Low range is 0.5 - 10 MPH in 0.5 MPH increments. High Range is 1-20 in 1 MPH increments. I would be surprised if you could change that.
Andy
Andy
The increments in low are .5 but it starts at 1.0 MPH and will not go lower than that. I haven’t tried it in the terrain modes but in 4Lo its 1.0.
MT19RANGER
JERRY
SIDNEY, MT
Nice to know, I'll have to test 4L.
Are you sure? I swear I saw it start at 0.5 when I was playing around with it a while back. Maybe I was doing terrain mode instead of just 4 lo?
Andy
Andy
I’ll play with it after work. I tried it this morning in just 4Lo and it would go no lower than 1.0 MPH
RagonkP1
TX
I just installed a Start-X remote start kit on my ā€˜19 STX with keyed ignition. I highly recommend this kit for anyone looking. Very quick and easy install and functions as advertised, unlike other kits out there.
Has anyone figured out the procedure to override the factory ā€œautoā€ setting for the climate control when using remote start and get the vehicle to retain the ā€œlast settingā€ using Forscan?
