FordPass app message
Glynn, I hard wired mine to the battery and ran a longer lead down and out through the front tow hook. This way it's easy to quick connect it without always having to open the hood to attach it.
I bought this one here with my FordPass points but you can by the same one on Amazon cheaper here. This is the longer lead if you decide to go that route.
Just remember to ground it to the body and not to the negative on the battery. This is where I grounded mine.
I ran the longer lead across the front and dropped it down to the tow hook. When you're not using it you can tuck it up inside the rubber boot on the tow hook. If you need any other pictures let me know and I can get some tomorrow when it's lighter outside.
I'm speachless..doesn't Graphine work under the hood?
? You're not supposed to look under there!
Yeah, I've been meaning to get to that. Out of sight out of mind. ?
OrangeStreak
New Mexico
It has been reported that you have the most serious case of atrophy ?‍⚕ on 5g from using this extender and the Damper...:stop: :facepalm:
It has been reported that you have the most serious case of atrophy ?‍⚕ on 5g between this extender and the Damper...:stop: :facepalm:
That's my excuse for the dirty engine bay. :rolleyes:?
dozxab
Prescott AZ
Isn’t the NEG terminal connected to the frame via a heavy gauge wire?
not seeing the correlation with your response
It ensures the (BMS) Battery Monitoring System sees the voltage flow.
