Ford pvc orange connector
Joranger2023
Ford ranger
Heavy equipment operator
Is there not a video anywhere of how to break or use a pick to get it off?
Joranger2023
Ford ranger
Part number?
is it this?
Joranger2023
Ford ranger
I was under the impression that Orange connector had to be broken to get it off for installing the Ford performance oil can separator?
Good to know
Joranger2023
Ford ranger
Does it have to be angled?
Excerpt from the manual
The orange style locking tab is not a (Quick Disconnect Style) See Below
NOTE: The crankcase vent tube may have either a permanent or quick connect connector at one or both ends. If the tube needs to be removed for any reason, the permanent connector(s) must be cut to remove the tube. The tube will then need to be replaced.
NOTE: If the crankcase vent tube is replaced, the replacement part may not come with a crankcase pressure sensor. If so, the PCM will need to be reprogrammed.
  • If equipped, disconnect the wiring harness electrical connector.
  • Cut the lock tab, on both ends.
    Use the General Equipment: Side Cutter Pliers
  • Remove and discard the crankcase vent tube.
Open In New Tab Zoom/Print
Installation
  • Install the new crankcase vent tube.
  • If the replacement crankcase vent tube part comes with no crankcase pressure sensor reprogram the PCM .
    Refer to: Module Programming (418-01 Module Configuration, General Procedures) .
  • If the replacement crankcase vent tube came without a crankcase pressure sensor, tape the wiring harness electrical connector back to the wiring harness.
  • If the replacement crankcase vent tube comes with a crankcase pressure sensor, connect the wiring harness electrical connector.
Excerpt from the Oil Seperator - Install Instructions
So, if it is Orange - It requires to be forced off (pried) or cut with side cutters
If it is Grey - It is a quick release - Ref: Note 3 and Pic
Loweredon33s
Baltimore
2021 Ranger
Performance person
Installation
  • If the replacement crankcase vent tube part comes with no crankcase pressure sensor, reprogram the PCM .
That was an awful lot of words but…. It comes off easily with the disconnect tool. It is not permanent and doesn’t need to be broken. We all thought it did at one time but it was wrong. It is indeed a reusable quick connect/disconnect.
Ok, I have not had it off (YET) but I guess the documentation from 2 sources is wrong.
Which source 2 is getting the info from source 1 as guidance (Ford Manual). ?‍♂ :headbang:
Thanks for the info
Loweredon33s
Baltimore
2021 Ranger
Performance person
Thanks for the info
I have broken them myself because people said to. I then stopped and listened and tried…. It released with the tool, I have done it multiple times now on customers trucks and it comes right off. Sorry to upset your book knowledge.
I did find it rather odd, that a manual would tell you to break something and is designed not to be removed without damage.
Loweredon33s
Baltimore
2021 Ranger
Performance person
I found out in a video after I broke a few. The cheap disconnect tool someone posted in this thread works a will release them.
Josebd
2021 Ford ranger xlt
Road maintenance county
does the tool have to be angled?
