Ford Pass Tire Pressure Incorrect
Rp930
Denver
Has anyone noticed the tire pressures on Ford Pass are no longer accurate?
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Mine never have been. Typically off by about 2psi
Rp930
Rp930
Denver
Jrel209
Wa
2020 Ranger XLT crew cab
Its always way off, and i swear the app says not to trust it.
Rp930
Rp930
Denver
I guess I’ll just quit using it.
Chris M
Surprise, AZ
Security Supervisor
Just figure out how much it's off consistently and work with that. It's only designed to be a rough guide anyway. That's how I do it.
Rp930
Rp930
Denver
It’s off front to rear. Like it’s just putting in a number. useless for me.
Rp930
Rp930
Denver
SymChris
Mississauga, ON, Canada
2019 Ranger Lariat FX4 / 2017 Escape SE FWD
Pretty sure it depends on the last time your truck communicated with that server/database. I’ve been home about 90 minutes and here’s what I go on both, truck reading first, app second. The app is just a guide (same with dash readout I guess).
JesseS
Jesse
NorCal (Roseville)
Mine is normally off by 1 psi cold front & rear, but the app does say to take the reading with a grain of salt as it may not be accurate.
JJG
KY
2019 Ranger Lariat Crew Cab
Make sure you pull down and refresh the app from the vehicle tab, so that it does communicate and update. Mine has always been accurate to what the vehicle says.
Mine have always been 1-2 lbs off on the app. When I check my pressure with the gauge it's always spot on to the dash readout.
I hardly ever use the app. Usually it's only for times when when we're out I second guess myself if I've locked the doors.
