First Road Trip
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
For the seat angle I used a half inch nut for the spacer, much less expensive for the same result. The bolts are plenty long to handle the extra height.
For the driver seat, I used the jackers. On the passenger seat, I used washers to get the height I wanted.
Bsthroop
Brian
New Mexico
2019 Lariat 4x2 Sport
Broadband/ Microwave Engineer
Yes $80 for a spacer seemed extreme
TICKLE ZOMBIE
TICKLE ZOMBIE
Florence SC
2022 Ranger XLT 2WD Sport
i have manual adjustment seats, no power.
What additional adjustments do the Lariat seats have?
When I was looking I don't remember any differences between XLT power seats and Lariat power seats.
And Yes, the Ranger is a pretty good highway travel companion.
Downright excellent for a truck.
Stevedbvik1
2022 Ranger Tremor XLT
Yes...Desert Does It.
The Jackers actually work very well....raises the front for a more comfortable driving position. Feels like a recliner. I used the 3/4 inch height for me. Several on the forum have purchased them. Personally, I wouldn't go back to the stock seat position. Price seems a bit high, but in this case you get what you pay for.
My seats are the power, but they work just as well on manual seats.
Did you try the 3/8 first or go straight with the 3/4’s? I purchased two sets and I am wondering what is the best route without trial and error. I’m 6’3 180lbs ish. The wife’s 5’10 XXXlbs ish ?
TICKLE ZOMBIE
TICKLE ZOMBIE
Florence SC
I’m debating same myself. The 3/8 shim looks small and maybe I won’t notice, so go straight to 3/4?
I am having my local garage install as I am not mechanically inclined, and have other parts need installed and an oil change is due soon anyway so I’m going to have them do it all.
I don’t want to go back and forth so I’m going to risk it and have do 3/4 from the get go.
Last car I had it had a bottom seat cushion tilt feature and I maxed that puppy out so I reckon the 3/4 will be the way to go.
They adjust exactly the same.
The Ranger does have a tilt function built into the height adjustment. If you lower the seat all the way it will tilt back slightly.
It's the pump handle on the side.
TICKLE ZOMBIE
TICKLE ZOMBIE
Florence SC
i know of the pump handle but personally do not feel any difference in tilt, I feel more like it’s raising me up and down.
Gotcha. I can feel a tilt in that movement as well. But if it's not enough for you to notice I bet it won't help.
Just didn't want you spending the reported $80 for a spacer if you didn't have to.
Just saw your question....
I went right with the 3/4 inch. I'm 5'10", 185 lbs. This was perfect for me as I like to sit high. The 3/4" raised the front to where it is ideal for me.
Wife is happy with the stock seat and adjustments, so only drivers side got a set.
Stevedbvik1
Thank you
TICKLE ZOMBIE
TICKLE ZOMBIE
Florence SC
I’m 5’11” and 185 so this confirms the 3/4 will suit me also!
saurigaiozi
Ranger
That ethanol-free gas at Buc-ee’s might actually make a difference—some people swear by it, especially for smoother performance. The mileage you’re getting is impressive too, especially with the extra weight you were hauling.
