Fender vent led
HarryManback
New England
2021 Ranger XLT Tremor
Electrical Engineer
Don't tease us like that. Got a link?
Middletown pa
2019 ford ranger
The leds are from aspect led. 36 leds per foot, had to buy a whole reel. They are wired to the headlight turn signal/ marker light. I bought a 10 pack of water proof connectors from Amazon so I could keep everything separate. The light genie reduces the power 30 percent when the turn signal is on. I originally bought a set of black fender vents but the magnetic metallic diffuses the light better than the gloss black. The vents pop off pretty easy. They can be taken apart with a small flat head screw driver by popping off the melted over plastic tabs on the back of the vent. I had to drill a small hole in the corner of the vent you cant see it once everything is together. Once the leds were installed I soldered a connector to the wires, put the outer cover back on and used a drop of supper glue on each of the tabs. Routed the wiring harness I made over the wheel well liner, tapped the light genie into the turn signal and parking light wires plugged all the connectors together and made sure everything worked.
HarryManback
New England
Electrical Engineer
Want to sell me some of that reel? Sounds like you might have some extra. This scratches my itch for turn signals in the mirrors and looks dope. I think I have the magnetic gray vents because of the Tremor. I'm running out of projects, this would be perfect!
Zeroedin
Matt
USA
2021 Ford Ranger Roush Edition
Well, I guess this is the beginning of the slippery slope down the forum-inspired rabbit hole for me. It also illustrates why every enthusiast forum I belong to greets new members with something along the lines of “Turn and run away….or be prepared to empty your wallet faster than you ever imagined!”
In the two plus months I’ve had my Ranger I’ve made quite a few changes. I still have quite a few more planned. But this is one that I never would’ve thought of on my own…..and now I’m pretty sure I can’t live without it.
Lol, so I’m gonna say ”Ugh” and “Thanks” at the same time here. It’s a very cool look and I’m really diggin’ it!
Jrel209
Wa
2020 Ranger XLT crew cab
Thats pretty cool, thanks for using amber and not neon green or pink
Jrel209
Wa
Ive actually kept record of the upgrades ive done haha…. Its not pretty
Add it to the list with all of ours in this thread. You can join the money pit club. ?
This forum (and most others) will do that to you. Heck I didn't realize I needed new tires until I started looking at everyone else's. Next thing I knew I had new ones and mine only had around 800 miles on them. Next came the level kit and from there it never ends. Of course the damper was right up there but I had to wait for it because it wasn't out until late 2019. Talk about stress! ?
Grooge
Fort Worth, Texas
Ford Escape
Popped off fender vents and installed some amber led's. Used some light genies found on ebay so they flash with the turn signals.
WoW!!! Genius!!! I just thought of this myself as I was think of my next project. Did a search and you already have it done. Very cool.
I did mine not too long ago and then found that OP beat me to it...can't keep a good idea down...?
