egr delete
BM1moose
Rich
Hudson Falls,ny
2021 ranger stx
information on egr delete ,how many members have done it and seen good and bad results
thanks
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
EGR delete, definitely a plus in a diesel, more debatable in a petrol engine.
In diesels getting rid of the EGR means getting rid of the black tarry mess that builds up in the intakes caused by diesel soot mixing with oil vapour from the PCV valve. As diesels run lean burn with a wide open intake all the time it doesn't affect pumping losses like it does in a petrol engine, where they usually run a stochiometric mix with a partially closed throttle and therefore could benefit from the reduction in pumping losses an EGR gives.
Also in a modern turbocharged petrol it actually might be useful to slightly lower peak combustion temperatures when running an alloy head. (which is what it is designed to do, in both engine types, to reduce Nox production)
The problem is, in a modern engine the EGR isn't an add on like it used to be, it is a carefully designed in and programmed part of the system. You risk unknown complications by changing just one part of such a system.
The biggest hurdle is - Recalibration of the PCM for a EGR Delete.
No one will do it (Legally) as it violates the Clean Air Act and face heavy civil fines and up until Jan 2026 they could also face jail time
it has been in the news - and all from disabling the EGR and Associated systems on diesel engines
For me the EGR Delete on a 2.3 offers no real benefits as far as performance
TJC
"For me the EGR Delete on a 2.3 offers no real benefits as far as performance"
I understand that you qualified your statement in 2 ways, personally and from a performance perspective. I respect your opinion.
But removing the system does offer real benefits. It simplifies the system resulting in removal of several serious points of failure. The biggest being coolant leaks into the EGR system going right back into the intake track then into the combustion chamber, for one. And related, engine overheating due to low coolant from those leaks.
Although not as serious, DPFE sensor failures causing rough engine performance and erratic transmission behavior / shifting.
Here's a more comprehensive list:
The biggest concern is the EGR cooler because it is connected to the engine's cooling system.
Performance - Meaning HP Gains etc. as I have a hunch this is the reason for the question.
Other than the EGR Cooler and the DPFE - the system as a whole is reliable, I do wish they would have designed the EGR Cooler so one could easily (by-pass) the 2 ports for a T-Shoot isolation pressure test.
TJC
I wish the EGR system wasn't there to begin with.
If it's really a concern, you could always trade the truck in for a V6 Frontier! They don't have EGR and therefore you don't have to worry about it!!!
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Agreed, the same applies here heavy fines being caught with any sort of EGR defeat whether it be electrical, ( resistor on the airflow sensor) physical, (blanking plate) or by re tuning it out in the PCM. Fines are not just for the user, they can track back to even heavier fines for the company which did it.
I laugh at idiots who buy blanking plates with holes in them in the belief that it will just let "a little bit in" so it won't throw a code, the electronics can sense what it considers a restriction, and it just opens the valve wider for longer.
The drawbacks listed below with EGR coolers are legitimate, were in fact almost a trigger for a class action over here for the Ranger 3.2 diesel with EGR coolers that failed so often that many mechanics suggested prophylactic replacement at around 160,000 Km to avoid the issues of coolant loss and engine overheating or even head failure. But this wasn't a problem of EGR coolers in general, just the shitty quality of the coolers that were fitted, which would crack internally from thermal cycle, and dump their coolant into the exhaust or intake. Plenty of other makes of truck never had issues with similar EGR systems.
My own view is that with Add blue Nox reductions systems now commonplace why do we need EGR on diesels anymore, as the catalytic convertor can take care of it now.
Reactions: TJC
TJC
And that is an excellent question, and goes to the heart of the discussion. There are better engineering methods to address the issue.... If it even is a serious environmental issue.
There are a great deal of people becoming very wealthy off of trading carbon credits. And honest science has proven the silliness of the CO2 scare. I consider it as nothing more than a massive transfer of wealth scheme.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
The current trend these days seems to be to manufacture something out of nothing. Carbon credits, new companies pushing vapour ware, being floated at waaay past their real value, insurance for one in 1,000,000 events, etc something has to give.
