egr delete
BM1moose
Rich
Hudson Falls,ny
2021 ranger stx
information on egr delete ,how many members have done it and seen good and bad results
thanks
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
EGR delete, definitely a plus in a diesel, more debatable in a petrol engine.
In diesels getting rid of the EGR means getting rid of the black tarry mess that builds up in the intakes caused by diesel soot mixing with oil vapour from the PCV valve. As diesels run lean burn with a wide open intake all the time it doesn't affect pumping losses like it does in a petrol engine, where they usually run a stochiometric mix with a partially closed throttle and therefore could benefit from the reduction in pumping losses an EGR gives.
Also in a modern turbocharged petrol it actually might be useful to slightly lower peak combustion temperatures when running an alloy head. (which is what it is designed to do, in both engine types, to reduce Nox production)
The problem is, in a modern engine the EGR isn't an add on like it used to be, it is a carefully designed in and programmed part of the system. You risk unknown complications by changing just one part of such a system.
