egr delete
BM1moose
Rich
Hudson Falls,ny
2021 ranger stx
information on egr delete ,how many members have done it and seen good and bad results
thanks
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
EGR delete, definitely a plus in a diesel, more debatable in a petrol engine.
In diesels getting rid of the EGR means getting rid of the black tarry mess that builds up in the intakes caused by diesel soot mixing with oil vapour from the PCV valve. As diesels run lean burn with a wide open intake all the time it doesn't affect pumping losses like it does in a petrol engine, where they usually run a stochiometric mix with a partially closed throttle and therefore could benefit from the reduction in pumping losses an EGR gives.
Also in a modern turbocharged petrol it actually might be useful to slightly lower peak combustion temperatures when running an alloy head. (which is what it is designed to do, in both engine types, to reduce Nox production)
The problem is, in a modern engine the EGR isn't an add on like it used to be, it is a carefully designed in and programmed part of the system. You risk unknown complications by changing just one part of such a system.
The biggest hurdle is - Recalibration of the PCM for a EGR Delete.
No one will do it (Legally) as it violates the Clean Air Act and face heavy civil fines and up until Jan 2026 they could also face jail time
it has been in the news - and all from disabling the EGR and Associated systems on diesel engines
For me the EGR Delete on a 2.3 offers no real benefits as far as performance
TJC
"For me the EGR Delete on a 2.3 offers no real benefits as far as performance"
I understand that you qualified your statement in 2 ways, personally and from a performance perspective. I respect your opinion.
But removing the system does offer real benefits. It simplifies the system resulting in removal of several serious points of failure. The biggest being coolant leaks into the EGR system going right back into the intake track then into the combustion chamber, for one. And related, engine overheating due to low coolant from those leaks.
Although not as serious, DPFE sensor failures causing rough engine performance and erratic transmission behavior / shifting.
Here's a more comprehensive list:
The biggest concern is the EGR cooler because it is connected to the engine's cooling system.
Performance - Meaning HP Gains etc. as I have a hunch this is the reason for the question.
Other than the EGR Cooler and the DPFE - the system as a whole is reliable, I do wish they would have designed the EGR Cooler so one could easily (by-pass) the 2 ports for a T-Shoot isolation pressure test.
Reactions: TJC
TJC
I wish the EGR system wasn't there to begin with.
