Does USB power continue when the 2019+ Ranger is turned off?
thesears
Kevin
Oakland, CA
2020 Ford Ranger Lariat RWD FX2
I have a 2020 Ranger Lariat. I want to insert a wireless CarPlay Device into the USB port so I don’t have to plug in the phone while I’m driving, but would power continue to be drawn on this USB port after the Ranger has turned off?
2020FX4
El Jefe
Los Angeles
2020 FX4 Ranger
I am not 100% sure I am correct and I am sure someone will chime in if I'm not, But I recall reading it at one point that the USB ports stay powered for 2 hours after ignition is off.
I believe the USBs stay powered for 60 minutes, They are not the same as the Power Points of 75 minutes, as they have separate power source.
fusseli
EE
Yes, they stay on for a while by default. You can also extend the time they are on using foreskin.
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
I think this is at least part of the reason I had two dead batteries. I used to leave my dashcam plugged in. It's kinda ridiculous for it to stay on so long.
I get a laugh everytime someone's autocorrect changes Forscan to foreskin. Unless you ment it that way?
Capt Jon
Jonathan
St Augustine, FL
I decided to find out. I use the Motorola M1 wireless adapter. I powered up the truck the M1 power light was on and I Let the M1 complete the connection to Android Auto. I removed the key exited the vehicle and locked the door. I timed the power light on the M1. I stayed on approx 10 seconds after I locked the door.
SILK
Ty
Eastern Pennsylvania
2019 XLT Crew Cab Sport, 2018 Santa Cruz Tallboy
IT Director
I believe this is the right answer. If you leave your phone plugged in after shutting the truck off, the device disconnects from CarPlay/AA and power as soon as you open the door, or after a short period.
