DIY Bed side mounts for acessories, Fire extinguiser, axe, shovel, tools, etc.
KnightRanger
USA
2020 Ford Ranger, 2016 Harley FLSS,
Note: This is an ongoing project, still waiting for bed led light and some misc mounts. Still need to decide on onboard air.
DIY Caveat: Need to drill 2 holes each side of the bed.
Pros:
Organize your bed and tools.
Place to mount your fire extinguisher, flashlight, etc.
Easy to remove DIY panels by loosening 2 nuts per side.
Versatility of the E track and attachment accessories.
Cons:
Need to drill x2 holes per side.
May not be the look you want.
( Im still waiting for Builtright Ind to make the Ranger panels)
So, took me a few days to decide wether I should drill or not ( dilema for lots of us here in the forum...lol ) But I need mounts and holders on the truck bed! I want to be able to hang my fishing rods too.
I am posting this, in case anyone wants to do something similar.
Most stuff you see in the pics are materials you can get from Lowes or Homedepot.
I used 1x6x6 (but its actually 1x5.5 wood) 1x4 for the inside attaches to the 2 main bolts in the pics. You may use whatever wood material and size, type you like.
Notes:
My Ranger came with a factory spray in bed liner.
It has the 4 pre existing oval holes on the bed ( see pics)
I decided to drill the holes 18 inches apart, near these oem oval holes.
(I used these oval holes to be able to insert the metal brace/ backing plates).
The bolts/ screws I used are zinc coated grade 8 hex M8 x 1.25 by 40 mm length. 5/16 washers and matching flange nuts.
For attaching the Black hdpe panels, the E track mounts and quickfist clamps I used zinc coated Tek screws 1.25” and 3/4“ sizes.
I used metal brace x4 ( see pics) cut into 3.5- 4 inches as a backing plates
for the bolts. The 3M strips are optional, but made it easier to attach the backing plates.(see pics)
I also applied anti corrosion compound around the holes after I drilled. (not sure if it helps)
I attached Circlip retainers on each bolt, to prevent it from going back and falling inside the bed panels.
I decided to use E-track singles as It gives me more flexibilty on mounting it just where I need it. E-track also offers attachments like hooks, hangers, cargo strap mount etc... I also bought one of their bin. It fits my Kobalt ratchet set and misc tools.
The black HDPE material I used is optional. You can get them from Amazon.
I had 12x12 and 12x24 in 1/8 and 1/4 thickness and only cut into the pieces I need.
(Use them to cover up the wood if you want).
I dont plan on mounting or putting anything heavy ( >10lbs)
So please use your judgment when you decide what materials you use,
( stronger vs weaker wood, brackets, mounts, etc) and how you mount your items and accessories in your truck bed.
So here are the pics,
aklinger
Toledo, OH
2019 Ranger XLT Sport
I'm considering building something similar to organize the gear in my bed. Thanks for sharing!!
KnightRanger
KnightRanger
USA
Added bed led light today.
The ones I got were a bit long, so had to make it like an “ L ” shape
to fit the sides. I also left some space in the rear for my hard cover pull tabs.
For power I just tapped into the existing oem power harness, right under the frame rail by bed on drivers side.
(This is the exsiting oem accessory plug if you order your Ranger with the utility power plug in the bed. If not, the plug is still there, but you have to get the harness to make it work. ( or splice it ) Lots of write ups already about this in the forum. :)
For the 2x4 cargo divider, I added a couple of plastic handles just to make it easier to remove/ replace.
So heres some more pics, now with the bed light.
Glocker
Boca Raton
Looks good! I'm going to be doing something similar (but different). I'm probably going to be running cargo dividers lengthwise down either side of the bed, about 6 inches in from each wheel well. That way I can hang longer gear off of each side of each divider. I'll be securing a HiLift jack, traction boards, and a shovel. My system will be modular for removal from the truck for hauling stuff when needed.
SILK
Ty
Eastern Pennsylvania
2019 XLT Crew Cab Sport, 2018 Santa Cruz Tallboy
IT Director
It makes me sad that there is not a factory bedrail system available and the aftermarket ones require drilling into the bedside. My brother tells me the most useful thing on his Frontier is the bedrail system. I wouldn't mind paying to have this in the Ranger, but I'm really not a fan of putting holes in my $35k+ truck.
Glocker
Boca Raton
Right! I drilled a huge hole in my fender for the Safari snorkel installation but still, the thought of drilling another hole in my truck hurts! LOL
RangerMunkey
https://www.ranger5g.com/forum/thre...ng-available-holes-that-sounds-so-dirty.9773/
I've got almost infinite mounting options and zero extra holes drilled... Maybe some ideas here?
SILK
Ty
IT Director
I like what you've done here. Is the cage part necessary, or can you just get away with the channel/SuperStrut and a sliding tie down? It seems, based off what you have, that it would be easy for an aftermarket company to develop a proper channel system with slideable tie down points using the oval openings available in the bed. Certainly easier than I had thought.
KnightRanger
KnightRanger
USA
Dr.Me
Daven
Kapolei,Hi
2019 Ford Ranger XLT FX4
:like:Nice, simple, and cheap i like it. Not so keen with the drilling though, might just try using existing holes myself:idea:
I like what you did with the fishing rods. Too bad most of my rods are over 5ft even after broken down:facepalm:
charwest
char & tony
On the road
2019 Ranger XL FX4 Supercab
Healthcare
Do you remember where you found the tool straps for the axe? I’m looking for something like that
KnightRanger
KnightRanger
USA
Glocker
Boca Raton
BHunted
Sumner County, TN
2019 Ford Ranger Lariat, 2019 Ford Mustang
Pros:
Cons:
Notes:
Really nice rigging.... Great job.
KnightRanger
KnightRanger
USA
Just an Update:
The panels are still holding up well.
Added my Viair 450 as onboard air, hooked up to a quick connect and 30 amp breaker.
Also, since I have a hard cover (Extang 2.0)
I decided to install some swivel tie-downs:
https://www.amazon.com/gp/product/B075QZTYTY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
To hold the pair of Recovery traction boards inside, high up
and out of the way.
(attached to the first, non folding panel of the bed cover).
