DIY: Adding the 12V Power Outlet Option in the Bed
Don B.
Don
Charleston, WV
2019 Ford Ranger Lariat
Is this the swing storage case that Ford is offering? I ask since I bought the case without realizing that the 12v is in the way so I now have to remove it and find another place to install.
Mine are the "Swing Case" brand but I suspect the Ford version may be made by Swing Case since they look so similar. After I installed the swing cases, I saw that I would have enough room below the bracket to install the 12v. So it is not exactly where most folks have theirs. The next chance I get, I'll get a photo.
SamoanMike
Michael
Huntsville
Ford Ranger 2019
Thanks! I think they are the same except $50 extra for the ford logo on the case. Beautiful truck by the way!
Don B.
Don
Charleston, WV
Thanks.
I was just lucky that it happened in that order.
Noel Willhite
Noel
Bonita Springs
2019 Ranger XLT
I was just about to buy the parts for this mod and then I got to thinking. Sure enough, I'm not the first to come up with the idea to tap into the trailer harness. I'm putting 7-pin connector on this weekend so I'm now thinking of getting this add-on:
https://www.etrailer.com/Wiring/Hopkins/HM47675.html
That'll save some time and money and it's a no-drill.
Love this, i can utilize my trailer package and spend $16 for the exact same solution . Thank you !
Living The Dream
Like mentioned earlier in the thread, make sure you get it from a place that offers easy returns.
I've tried 2 different ones and neither works because the "smart tow" functionality of the trailer hookup doesn't sense a trailer being connected and therefore doesn't energize the connector. No power out.
If someone finds a version of this that works with our trucks, please post up!
mbergthold
Woodland WA
2019 Ranger Lariat Supercrew 4x (formerly)
Nice clean install. Any ideas on how to get a 110v outlet extended from the console to the bed?
JimH
Palm Coast, FL
2020 Ford Ranger XLT SuperCrew
Check this kit for a 12v outlet - https://wolfhaus01.square.site/ . Hole and plug are already in the truck, took me about 10 minutes to install the kit! I recommend it very highly!! (Click on the Shop Now button to see the options available).
Noel Willhite
Noel
Bonita Springs
2019 Ranger XLT
Do you have installation instructions? Curious on how you got to the other side of that hole in bed
JimH
Palm Coast, FL
The plug has two arms that swing out behind the hole to hold it in. You just feed the wire down the fender, remove the blank plug located on the truck harness, plug in the wire from the plug, then seat the plug into the hole, turn the hex head screws and the arms swing out behind the bed to secure the plug. Tighten the screws until the socket is firmly in place and you're done. He even includes 2 extra arms in case you over tighten one and break it. Also includes the required hex wrench. The whole process took less than 10 minutes. Picture shows the arms.
Hi Jim,
Great design! Just ordered. Thanks!
VAMike
2019 Ranger Lariat SuperCab
so what is actually installed on the bed? some kind of proprietary connector?
JimH
Palm Coast, FL
Yes, I suppose it is, but readily available so you can make a wire for anything you want. I ordered the plug with a 3ft pigtail which I'll put a plug for my RC model battery charger on so I'll be able to charge my batteries at the flying field on the tailgate instead of inside the cab (much safer)...
You can also order the cable he has with a power socket which gives you a standard power outlet.
RoadBoss
Travis
Lakewood, CO
www.TJAoutfitters.com
anyone know approximately how long the 12v bed outlet stays powered for after the key is off?
I just used this connector to power my DC to DC charger for my aux battery system before I realized that it stays on for a while... I'm a little worried that it could potentially drain my starting battery if I'm running a lot of load on the aux system before the outlet switches off and fully disconnects the main battery
