DEEZEE noise
HeavyDuty
Kevin
East of Nashville
2021 Lariat, FOX 2.0 (set at 2"), 275 65 R18
Builder, Restorer
Seems like a ridiculous issue when I read some of the other stuff you guys and gals are going through with your Ranger but bothers me nevertheless. I want to replace with OEM part. It works fine but it is noisy now. Tried a couple things but it has had a better day. It is only on the left side. Anyone replace theirs yet?
It’s not so much the actuator, it’s the pressure it puts on the left hinge assembly , if you spray so lube on the hinge it quiets the noise.
This is (1) drawback of having it installed and the rub spot on the support cable getting pinched.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
No and it is 5 years old.
There is no "OEM" part.
Noise is most likely coming from the tailgate hinge 's.....the rubbery/plasticy piece. Spray them down with some silicone or even WD40, or any spray lube.
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
Oh I though it was stock on the truck which is why I figured OEM. I'm going to give the spray another try and be a bit more generous. ;)
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
So this time I was generous with the lubricant and the rub squeaky noise is gone.
So thanks for the replies. The damper is actually working fine.
:sunglasses:
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
And now that the DEE ZEE CEO is in Arkansas it will sound like a pig squealing when it needs to be lubricated. However, you will know in advance when the squealing is going to start because you will hear what sounds like a banjo being played.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Just a reminder for all...that actually was all in GA, not AR.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
They are like minions and Dave the evil boss has worldwide control.
Hello,
I installed a deezee tailgate damper about 6 months ago and have not had much problems with it at all. During the winter I did notice it squeaked a little but read it was due to the temperature. Over the last few months the noise hasn’t gone away and the squeaky noise has gotten louder and worse I’ve tried wd40 but don’t know what else to do does anybody have any recommendations? Thank you
You got a Friday damper...just buy another one on Monday...it's cheap enough...mine's been flawless for the last 130K miles...
JesseS
Jesse
NorCal (Roseville)
I can vouch for Dave's solution...it is the plastic bushings.
I shot some Dri Lube in mine several weeks ago...still quiet. :like:
Yep, I used the slide lube for my M/H (dry-lube), worked fine.
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
Mines working great and quiet.
Just needed to get the lubricant in the right spot.
