Cooper Rugged Trek Air Pressure
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
If anyone needs to know what Cooper recommends for the Rugged Trek tires in 265/70r17 LT I received this when I asked.
Hello Andy,
Thanks for your email. Because you went from a standard load, 4-ply rated tire to a load range E, 10-ply rated tire, you can bump the air pressure up a little bit. We would recommend between 42 to 45 psi.
Have a Great Day!!!
Eric
Consumer Relations Specialist
Cooper Tire and Rubber Company
1-800-854-6288
Monday-Friday 8:00am-5:00pm EST
Burnt Money
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
The chalk test is the only real way to accurately figure out what pressure the tires should be at.
I agree 100% on the chalk test. I figured the information from the manufacturer would be a good starting point.
Burnt Money
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
Yes, in the initial email I stated it was for a 2020 FX4 Crew Cab with the towing package. I figured there could be different recommended pressure between a Ranger and 1 ton.
mtbikernate
NC
2019 Ranger XLT 4x4
it's an interesting thing to me that for truck tires, when you get a stiffer sidewall, you increase the pressure (at least for road use, I guess).
but in mountain bikes (which I'm more familiar with), using tires with a stiffer sidewall means you drop the pressure.
JCMAC
Richmond Ontario Canada
2019 Black Ford Ranger Lariat FX4, Sport Pack
Retired Systems Analyst
Hello Andy,
Have a Great Day!!!
1-800-854-6288
I have had the 265/65/17 Lt tires and factory recommended pressure is 38 psi. That included the punishing ride. I can only imagine how rough the ride is at 42-45 psi. Additionally when off roading the normal case is to reduce tire pressure substantially.
Burnt Money
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
It’s not bad at 40psi but they are also brand new. I’m going to chalk them the first day it’s not going to rain and see how they look.
I recently got rid of the OE tires on my Scab which were nothing more than big car tires, at 32-34 psi, and had a set of Yokohama Geolander G015 E rated 10 ply's installed. Went with E rated as we tow a heavy travel trailer with around a 700 lb tongue weight.
When running daily pressure is at 40 psi all around. When we tow I bump the rear's up to 50 psi....makes a huge difference when towing...no more sidewall flex and no "squiggling"....rig runs straight and true.
I do not find the 40 psi, when running empty/daily driver to be harsh or punishing....only really noticeable when there is a bump like a transition going over a bridge. I would guess that the psi to run in your E rated tires is all dependent on the load you carry and the road surfaces you encounter daily.
Whiplash
Kern
The southwest Missouri Ozarks
2021 Ranger XLT FX4 / 2004 Mazda RX8
I have Cooper Rugged Trek XL rated , reinforced sidewall, 255 / 70 / R18 , on my truck....I have a little over 2 years , almost 10, 000 miles on them....
Chalk tested , 30 psi front , 28 rear, with about 150 lbs in bed.....I keep them at 32 front 30 rear....I will air down to 16 lbs sand , 18 -20 rocks ,
I have rotated and balanced them twice, at every oil change....They are wearing evenly across the tread pattern, even with my out side of Ford spec alignment numbers...( high Caster ) ......Good Tires....
I would only run that high of a pressure if I wanted to feel ever bump in the road. I say start with the door placard pressure and go from there. Mind you I found 30-32 PSI both front and rear to do just fine for me.
