Cleaned the TB and Map sensor
21rangerCactus
Self employed
My truck has been acting a bit wonky past few months. Shifting up and down, slipping in certain gears/holding rpm longer, and erratic. Thought maybe it was time to change the transmission fluid.
Today I decided to check out by TB and MAP. As you can see in the pics they had a bit of crud on them. First time this has been done since I've owned the truck when new and now it's at 140k.
I'm happy to report it's driving fantastic. Shifting nice and smooth like the day I got it back from the transmission shop after the rebuild. Gas mileage is also going up back to where it used to be.
Are you using the OEM paper air filter? Just curious.
21rangerCactus
Self employed
Up until 115k I did. Now I have a mishimoto intake.
Though that doesn't have anything to do with oil being on the back of the TB and on the MAP. That's from blow by. A catch can could help but I've never been a fan. Don't see a need for it on a stock vehicle. The amount of crud I had wasn't to bad for 140k. I will now start cleaning it every 20k or so. Same as I used to do on my previous vehicles. Not sure why I neglected it on the ranger.
21rangerCactus
Self employed
I am curious about your usage up to that point? Tow or haul often?
I've towed a few times and nothing heavy at all..
My truck sees a lot of city/hwy driving and idleing. I use it to see my customers and for a few years I did Uber and lyft.
At 1k I tuned it. Majority of its life on the 87 tune. 100k I added a intercooler. 115k I added a larger turbo inlet and Cai.
Like I said in the other reply. This isn't really bad for 140k. In my other vehicles I'd clean the tb and maf sensor every other oil change/~20k.
Rrrr-Anger19
Ryan
Illinois
Unemployed
Thanks! Was wondering what to expect under mine when I get to it this spring. Being a touch under half your mileage but very similar usage I have a baseline to compare against.
I will say the MAPT was pretty bad, and this carbon buildup now cleaned most likely was the majority root cause of the shift issues.
The MAPT is part of the engine load calculation and engine load factors shift points, so the carbon was creating a (delayed) response
Good - quick and easy fix :thumbsup:
This is how the DPFE issues can also mimic transmission issues - the EGR Flow feeds the Intake and the MAPT sees that flow
21rangerCactus
Self employed
I would say it's bad due to my negligence. In my fbodys and my gto I cleaned the TB, intake and maf every other oil change. I think because they are upfront in eye view is why I remembered to clean it. Where as the ranger it's not at eye level and so I just didn't think about it. When Dereku made his post about cleaning it, the light bulb in my head started blinking.
And you are 100% correct. A dirty map can definitely throw off how the transmission shifts.
TJC
Another maintenance note going into my Ranger Hints and Tips Check List Note Book.
This is one of the primary reasons why I keep following this Forum. Tidbits just like this!
TJC
Titchadesh
Cody
Utah
2019 Ranger Lariat FX4
Aerospace Master Scheduler
Thank you for the link! It's been added to my notebook. Ford apparently doesn't make anything easy. A 15 minute job on my older autos. A bonding experience on my 2020 Ranger!
No worries, I didn’t include any photos because another user already posted some earlier in the thread—they can also be helpful for reference
