Cigarette Lighter Plugs too deep?
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I've been trying to track down an issue for a little while now, I noticed that a recent upgrade to my USB charger it seems that it wasn't always making a good connection, especially on off-road trips, but after digging into it, it looks like it was fine in circumference, but the lead on the end sometimes stops making a connection.
I also have a new plug I'm trying for a temporary chase light that also uses the 12V plug, and it seems to have the same issue, though it makes even better contact around the sides.
Has anyone had an issue with our plugs? If so, have you found a solution to the depth of them to maintain better contact?
gbritt89
Garret
Fort Worth Texas
2019 Ford Ranger STX
I used a Ridgid 100 watt power inverter in my truck and it was snug, I would say the issue lies with whatever you're plugging into the cigarette lighter adapter. Looks like you're able to wiggle it pretty easily. How many other devices do you have that can plug into the CLA's? Is the issue just with the one device or numerous?
Gizmokid2005
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I have this issue with multiple plugs (some are worse than others), and both of the 12v plugs have the same problem. It's just like the outlet has been altered to be just a little too deep somehow.
WhiteBeastRangerNick
Nickolas
Issaquah, WA
2019 Ford Ranger Super Crew
Field Calibration Technician
I’ve had to replace both plugs twice now. They’re very low quality and the solder on the back of them sucks so the positive lead stops making contact. I’m now replacing both plugs with after market plugs and rewiring.
Cabose-1
Eli
Student
I have a problem with the plugs too. They keep coming out. Has happened many times. Cant tell you what the fix is. I just keep pushing them back in. Annoying I know ?
Dereku
Chicagoland Area
There is an inappropriate joke here. But I have the issue with the AC plug in the back. Dealer is looking at it now.
