Blinker Issue
carbonranger
Blake
CA
2022 Ford Ranger FX4
Is anyone else here having any issues with their blinker taking a few seconds to come on after turning it on? It doesn't do it everytime but it's pretty consistent. And to clarify I have topped off the blinker fluid.
JustinR
Justin
Long Island, New York, USA
2022 Ranger/2014 MKX/2023 Nautilus/1981 DeLorean
I had had an old Jeep that used to sometimes signal the wrong direction when it was supposed to do the three-flash lane-change.... Current cars don't have mechanical flasher mechanisms anymore; rather it's done in software/firmware. Reboot maybe? :)
Do both sides do it?
Have you altered the OEM bulbs or circuit in any way?
Operation:
SCCM - Steering Colum Control Module - Monitors (Switch) position (Turn Signal, Hi-Beam, Flash to Pass)
Sends MSG via HS-Can2 to the GWM (Gateway Module)
GWM sends request over HS-Can1 to the BCM
The BCM provides the (On/Off) voltage for the Turn Signal (Integrated Flasher)
So, it could be a delay from the Can-Bus, Bad switch, bad SCCM or BCM
Does it do the same if you cycle the Hazzard Switch?
This provides a separate way of activation
Does it do the same delay (when you select high-beams or flash to pass)?
If you have the same delay, then it is a possible switch issue.
One common for both sides (Left/Right) is the Ground Point for the lights themselves, I would check this for a good ground and security.
G-123
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
There might be gas in the blinker fluid
