Biggest tire size?
BNJF
Bill
MD
2017 Tacoma 1990 5.0 Mustang
Self Employed roofer
I just bought a 21 xlt for and I'm already looking at lofts. What it the biggest tire size that will fit on the stock 18"
black wheels?
t4thfavor
Chance
I read all 30 pages of the tire size thread, and I still don’t know the answer to this question.
I just installed the fox coil over kit and the rear shocks and my truck skipped leg day for sure.
Robisten8
Central Texas
2020 Ranger XLT Sport 4WD, 2021 Bronco Sport
There are so many threads on this topic. Your answer is already here somewhere whether it be stock height, level kit or lift. It's all here, you just have to do some searching and reading.
At stock height most likely 265/65-18. Is you put a lift/leveling kit on then you should be able to fit a 275/70-18 on the factory wheels with no rubbing. How did I come up with this? Well.it has been proven that a 34x10.50-17 will fit and that tire is .3 inches taller and the tread is .2 inches narrower than the 275/70-18. For the small difference I say it should fit as long as you put a lift or leveling kit on.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
32” maybe 33” stock is gonna be about as big as you can go
brad_4200
Brad
2021 Ford Ranger Lariat FX4
Engineering Manager
I'm following this one also. 2" fox leveling kit will be installed on Thursday. I'm looking really hard at the Nitto Ridge Grappler 265-70-18, but would really like to confirm no rub. May end up with the 65 just to play it safe.
brad_4200
Brad
Engineering Manager
got my leveling kit installed. the guy at the shop seemed confident that 265.70.18 would fit. would still be nice to see if anyone else has done it.
Protomeister
2019 Ford Ranger Lariat - black/ebony with BAP
@BNJF , @brad_4200 , @t4thfavor , what did you end up doing? I'm in a similar situation, just did 2.5" level and Bilstein shocks/struts. Black 18" stock wheels that came with the black appearance package.
Thanks!
t4thfavor
Chance
I did 265/65-18 bfg at ko3, and a fox 2” kit set at whatever it comes set to at fox.
brad_4200
Brad
Engineering Manager
Thanks!
I did end up with the Nitto's 265-70-18. No rub or any issues there, have been running them for 2 years.
