Bed tie downs
I found this a few weeks ago, did it, and couldn't be happier. Works great.
Interesting solution. If you don't trim off those hanging chain ends, I'd expect that would rattle quite a bit. Do you find it rattles when driving? That is the only concern I'd have with doing that, otherwise it is a very ingenious, simple solution.
Filobeddoe
Greg
NE PA
2019 Ranger Lariat FX4
Great Idea!! If you're alittle OCD like me - Spray the chain with PlastiDip. Problem solved :)
ryyck
Charlotte NC
I just burned through a hundred bucks in Ford Pass points getting the 2 lost tie downs. If I'm going to loose the points by not using them...I'd rather get the tie downs.
I can't believe it.
I just tried to install the 2 tie downs, with the Ford bolts, and I can't tightened them down. It must take a hell of a wrench to seat these things. I used a hammer drill and only got about halfway. It'll be a trip to Atlanta for help with the kid...again! LOL...dam.
Sailor
South of Saskatoon
2019 HPR Ranger Lariat
Once I cleaned out bolt holes from the excess spray from the bed liner with a tap (from a tap and die set) my bolts installed with no problem.
ryyck
Charlotte NC
LOL...I was gonna try that. But I was hoping the bolt would do that for me. It'll take a little more work. Thanks.
Hi Folks,
You can make a poor man's tap using a old bolt of the correct thread and diameter. Take a V file and file two groove in the bolt deeper at the start and less further up by holding the file at an angle for each groove....then take it slow and extract to clean out the grooves frequently....slow, but it will work most of the time to clean out clogged or damaged threaded holes. works on spark plug holes as well....just fill the grooves with grease to catch any shavings...
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
If you're cheap like me this is under $20 for four. Amazon and Ace hardware. Looks like a robot face.
I'll be doing the same thing. The price ford wants for the correct ones is insane. Do you happen to remember the bolt size/pitch?
Rviator
FLA
retired aerospace engineer
Tightening the chain adds shear to the bed tie down bolts, which is then magnified by adding the cross bed tie. There is a demonstration in basic college statics class where the professor bets he can defeat the entire class in a tug of war. One end of a rope is tied to a fixed object, the students pull on the other end. The prof then pulls laterally on the middle of the rope winning the bet.
Blue Streak
Larry
That is why I like my rope. No direct pull from corner to corner except thru my cargo net. Depending on load I will double up 5in hooks using the factory hooks on the corners to raise the net using either the net hooks or maybe one 5in hook for other connections. Also it gives me connections front & rear.
Martyd
Marty
CT
2020 Ranger XL,2018 Mazda CX-5
They are M8 1.25 pitch and pretty sure 25mm
stevensc
Thibodaux Louisiana
Ford Ranger 2019 XLT
Retired seller of Sugar Cane Equipment
I bought these metric eye bolts on ebay or amazon last year they werent too expensive they are Stainless steel and fit in many of the threaded holes in the truck bed check your thread size
Hi Steve,
Got a link? Most of the threaded holes in the bed are M8x1.25 or M6x1.00
Fawnbuster
Indiana
Retired 34 years as LEO
Has anyone moved or attached new tie downs in the rear of the bed? I can't hardly reach the factory loication.
I had some leftover Ratchet strap that I leave looped in mine. I plan to lengthen the ones in the mid and front of the bed and velcro them up near the bed top so I can reach in without crawling in.
stevensc
Thibodaux Louisiana
Hi Folks,
Just installed a few minutes ago. Threads in the location shown for upper and lower hole are M8x1.25. Had to drill out one hole caked with spray-in liner using a 17/64 drill bit before I could clean up the hole with my M8x1.25 tap.
best,
