Gizmokid2005
- Joined
- Dec 1, 2019
- Threads
- 13
- Messages
- 1,279
- Reaction score
- 1,875
- Location
- GA
- Website
- gizmokid2005.com
- Vehicle(s)
- 2019 Ford Ranger XLT 4X4 SCrew
- Occupation
- SQL Developer
- Vehicle Showcase
- 1
This is also *highly* dependent on load conditions (accelerator position, incline, resistance, etc), it won't exclusive go 1-3-5. Typically it will skip second on a "normal" acceleration, but if you don't increase a bit it will go from 3-4-5 instead of skipping 4. Having been a bit more spirited lately, I've gotten to going 1-2-4-6 instead, but it's easy to manipulate with proper throttle response.If the latest software had taken hold, your trans should be skipping, most of the time,
2nd gear, and most likely, 4th too.
My trans is shifting, mostly, from 1st-3rd-5th, and this same action has been reported by other members here, in some of the threads.
Is it possible your trans has a earlier build date/maybe needs this update?? at the very least, if no codes present, I would ask for a KAM/adaptive memory reset, make it relearn.
That seems accurate, 1-3-4-5 is common for low speed and low acceleration.Thanks for the pointer on the gear selection, John. I've been too lazy to look into it on the XLT and had never used sport mode manual gear shifting. So far the pattern has been 1-3-4 at low speed.
I will, thanks!
