Deleted member 773
- Thread starter
- #1
My truck had an occasional shutter when cold started, ended up taking it in when the passenger USB port stopped working, along with the brake light recall and clunky shifts.
They figured out it was a bad plug causing a misfire, after moving the plugs around and cold starting again the misfire moved to a different cylinder. All plugs were replaced and the issue went away.
I had them update the transmission too, it was clunky when cold in 2-4th. Now it shifts differently, most often 1-3-5 etc, which is how most people here report it doing, instead of every gear like it used to, regardless of acceleration, and is very smooth now.
USB port was also replaced, it failed for some reason.
