Grooge
- Joined
- Mar 18, 2021
- Threads
- 11
- Messages
- 128
- Reaction score
- 360
- Location
- Fort Worth, Texas
- Vehicle(s)
- Ford Escape
Awesome. Thank you. I will look at the box this weekend.@overanger has a picture with his hand showing a small bundle of wires, these are the 6 seperate auxiliary outputs. Separating the bundle will reveal the individual wire colours (each circuit).
When a upfitter switch is turned on, 12v will be available on its respective circuit via a fuse and a relay. To quote from @Overangers manual, Switch 1 is a 25Amp supply connected to the yellow wire.
If you wanted to connect a set of spotlights for example, the positive wire of the lights could connect to the yellow wire and the negative wire to the chassis. These lights would then be controlled by upfitter switch 1 - as long as you respected the maximum current draw.
