claflico
Just installed mine in my Lariat today but it's not working. Went with the "unfold on ACC" option.
Red wire is connected via ATR fuse tap plugged into #30 fuse location. Have confirmed with multimeter that I get 12.2V on the module side of the blue crimpdown.
Used the blue squeeze tap with blue male connecter to connect the module blue wire to the truck grey/brown wire. Don't have a test light but the multimeter touching the module side of the crimpdown jumps up to about 7V then back to 0 whenever I push the lock button in the door.
With the truck turned off and the module connected to the truck wiring harness, the mirrors fold in when I plug the fuse tap to #30. When I press the start button the mirrors fold out.
When I press the fold button the mirrors still fold & unfold correctly but when I push the door locks with either the inside door button, outside door button, or key fob button nothing happens. Have reseated the black module to the white connector several times, have disconnected & re-connected wiring harness several times, have disconnected & reconnected fuse taps several times.
I ran out of daylight but I'll try to mess with it some more tomorrow.
EDIT: Got it working. During one of my disconnecting/reconnecting the splice into the lock wire I evidently bent the pin so that it didn't go into the groove...was too dark to see it until the next day.
