Alignment Question
billybos
William
New York
Ranger
plumber
Good evening everyone I just did a 2 1/2” lift and put new tires on the ranger due to premature wear. had them do an alignment and to me it does look like it is sitting right in the front. My old tires whore out prematurely on the outside on all 4 tiers. The question is do you think they did the alignment correctly or even at all. Here is a picture
Jason B
2021 XL STX SE 4x2
machinist
From that angle, looks like too much camber, which would lead to wear on the outside as stated.
Who did the alignment, and did you get a print out of before and after?
billybos
William
New York
Ranger
plumber
[/QUOT
no printout
Joeiconic
Under-inflated tires is also a common cause of excessive wear the outsides, especially if you’ve also been out of alignment.
TxOTRRanger
Clay
Elwood, Texas
This
Kinda looks a little bowlegged
If it was just done, may need some time to settle?
And This lol🤣🤣🤣
billybos
William
New York
Ranger
plumber
Update
Went back to the original place that did the wheel alignment and they said they only can do the alignment to the vehicles specifications.
went to another shop and they did the wheel alignment for me and used rough country’s specifications and everything seems to be fine
2021Ranger
Barry
NJ
2021 Ranger
With a 2 1/2 lift I the front I don’t think you can get the camber back to 0* where it needs to be.Did you get a print out?
billybos
William
New York
Ranger
plumber
No printout but he got it as close as he can
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
From what I have heard, with the lift it almost necessitates new aftermarket Upper Control Arms (as the lift uses up much of the range of motion of the upper ball joint, which might interfere with the alignment??). Did you go that route or just the above the strut spacer??
billybos
William
New York
Ranger
plumber
From what I have heard, with the lift it almost necessitates new aftermarket Upper Control Arms (as the lift uses up h of the range of motion of the upper ball joint, which might interfere with the alignment??). Did you go that route or just the above the strut spacer??
No just the spacers
