ISUACE
Where is this? Kinda hard to tell from the photo.here the route instead of through the firewall (thereis a special part to go in for the cable)
I see...need to look on the passenger side for US version...what is that orange line?2 pics more , it isa french ranger raptor (2l bi turbo diesel engin!!) it can be different from US!
incide:
motor side:
sorry for my english!!![]()
So were you able to confirm 33 is constant power? I started another thread looking for help to find a constant power but haven't got any help. Can anyone here help? My dash cam park mode requires a constant power, an accessory power then a ground.I had the windows down and left the truck in the garage for an hour came back and the lights are still going!!! Maybe I should try another fuse slot.
I almost certain 33 is constant, since the pod lights never turned off! But I didn’t do too much investigation since I found a slot that wasn’t.So were you able to confirm 33 is constant power? I started another thread looking for help to find a constant power but haven't got any help. Can anyone here help? My dash cam park mode requires a constant power, an accessory power then a ground.
What fuse is it attached to?Here is my tap...
Fuse 29What fuse is it attached to?
Check that. Changed it to 37. It's only hot when the accessory power is on.Fuse 29
