5G Dan-O
- First Name
- Dan
- Joined
- Nov 20, 2021
- Threads
- 10
- Messages
- 217
- Reaction score
- 280
- Location
- Morrisville, NY
- Vehicle(s)
- 2020 Ranger
- Occupation
- Ford ASSET Instructor - Program Director
Its a fresh install with 2.3.48.There was a software update to 2.3.48 - do you have that installed?
@CHrisin can you verify what version of FORScan software you have?
One of the best things I ever did.
- Swap XLT cluster for stupid Lariat crap.
Yeah I was just reading that, What is the difference in the buttons? Did you find a want to change your mileage? My truck has less than 10k on it and every cluster I find is 20-30kOne of the best things I ever did.
Don't forget the RH steering wheel buttons since you have to pull the wheel to install the ACC buttons on the LH side.
People have done it without removing the steering wheel but the amount of standing on your head (figuratively, of course) did not outweigh the extra 2 minutes it took to remove the steering wheel.
IPCBack to the topic at hand (my fault)
Can someone please update/share the exact list of modules that needs to be altered when adding ACC?
I'm headed to the lab where I can dig around with the IDS and the FDRS to see if they can be done the 'Ford' way.
IPC
720-01-01 xFxx xxxx xxxx
720-01-02 xxxx 9xxx
IPMA
706-01-01 xxxx 9xxx AAxx
706-02-01 xxxx xxxx 7Fxx
BCM
726-13-01 xxxC xxxx xxxx
SCCM
724-02-01 xx2x xxx xx
CCM
764-01-01 24VV VVVV VV CS
764-01-02 VVVV VVVV VV CS
764-01-03 VVVV VVVV VV CS
764-01-04 VVVV VV00 00 CS
764-01-05 0000 00 CS
V = Asci decoded VIN
CS = Checksum
APIM
7D0-01-02 x2xx xxxx xx CS
7D0-0202 xxx8 xxxx xx CS
I believe CHrisin also used:
PCM:
7E0-01-10 > xxx3 xxxx xxxx
ABS:
760-03-01 > xx31 xx
For US trucks: 760-03-01 are coded differently:
Our trucks have xxx4 - xxx7 (my decoding says EVEN 4,6 has no Trail Control while Odd 5,7 do)
Also our PCM does not have a 7E0-01-10 block. We start @ 7E0-162-01
Hmm, now you've piqued my interest.Looking further at this data:
ABS Blocks 760-03-01 decode like this:
No options 0004 6F
ELocker (FX4) 0005 70
+ACC 0006 71
+TrailControl 0007 72
So 760-03-01 should be 6 or 7 depending on your options. with a CS or 71 or 72
