2021 Low/Dirty Coolant
dguns18
Eric
Milwaukee,WI
2021 Ford Ranger Xlt FX4
Hello,
I have a 2021 Ford Ranger with 78k miles. While getting ready for a big trip, I noticed my coolant was low/dirty, no other issues. I filled it up with new coolant, and went about my business. Drove it 2800 miles in 7 days, from WI to NM and back hauling a 1800lb trailer. Never had any issues, did not overheat, and was all around perfect. When back at home I checked and the coolant was low again/ dirty. Reading online, it seems like it could be any litany of scary issues, including head gasket issues or EGR issues. I have not had any other symptoms besides the low/dirty coolant. Oil was changed right before the trip and looked fine.
Im thinking I will flush the coolant system and fill it back up again and monitor. Is there any danger to this, or what next step should I take?
Thanks
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Rinn69
N. Central Iowa
Retired USAF MSgt
Hello,
Thanks
Define Low - How much coolant loss, keep in mind that the normal range is between max and min in this example (borrowed pic)
Mine stays right at the (seam of the tank)
dguns18
Eric
Milwaukee,WI
When i first noticed it it was a 1/2 in below the min, so I filled it to the max line, and now after the 2800 mile trip its down just below the min line again.
There aren't any other symptoms to indicate it's the head gasket ( my biggest fear), so hopefully I can pinpoint a leak and/or maybe the fluid is just old and dirty after 78k miles. I have some UV dye arriving tomorrow and enough fluid to drain and fill the system.
I would just drain and fill and as precaution (preventive) replace the reservoir cap.
If it's really dirty it would be a good idea to flush the system, but that is more involved remove the radiator and T-Stat.
If it has a leak, it's a very small leak and may show with a pressure test of the system (including the cap) ensure it holds 21 PSI
Ddewitt88
2020 Ranger STX
Industrial Electrician
Put a flashlight to it. May not be as dirty as you think
ControlNode
Eastern NC
Computers
Did someone put green coolant in it? I thought it should have been orange or yellow.
dguns18
Eric
Milwaukee,WI
Highly doubt it... ive only had it in for 2 oil changes at the Ford dealership a couple years ago, everything else ive done myself and only just added some yellow 2 weeks ago.
I hate to say this - but to me it appears oil is getting into the cooling system.
The brown color plus (if not just the light reflection) misleading the pic. The white film floating on top of the fluid.
Have you checked the engine oil - Under the Cap and Dipstick for a white filmy sludge.
dguns18
Eric
Milwaukee,WI
I wouldn't say there's any white film, that mightve been a reflection. Im doing a "flush" with distilled water and prestone cooling system cleaner, and see where that takes me. And no white sludge in either of those places
Ok, so this is just a reflection of the bucket.
This is what caught my eye
dguns18
Eric
Milwaukee,WI
Yeah thats just my garage door and the sun.
