leafer
- Thread starter
- #1
Here are Shop Manuals for 2019 Ranger. What I have so far (attached ZIP file with many PDF's for each category). Will be adding more so check back...
100 - General
200 - Chassis
500 - Interior/Exterior Body Panels
100 - General
200 - Chassis
- 204-00 Chassis General Info (Ride Height, Suspension Diagnosis, Camber & Caster, Tow Adjust, General Suspension Info)
- 204-01A Front Suspension - RWD
- 204-01B Front Suspension - 4WD
- 204-02 Rear Suspension
- 204-04A Wheels and Tires
- 204-04B Tire Pressure Monitoring System (TPMS)
- 205-01 Driveshaft
- 205-02 Rear Drive Axle and Differential
- 205-03 Front Drive Axle and Differential
- 205-04 Front Drive Halfshafts
- 206-00 Brake System General Information
- 206-03 Front Disc Brake
- 206-04 Rear Disc Brake
- 206-05 Parking Brake and Actuation
- 206-06 Hydraulic Brake Actuation
- 206-07 Power Brake Actuation
- 206-09 ABS and Stability Control
- 211-00 Steering System
- 211-02 Power Steering
- 211-04 Steering Column
- 211-05 Steering Wheel and Column Electrical Components
- 303-00 Engine System General Info
- 303-01 2.3L EcoBoost
- 303-03 Engine Cooling 2.3L EcoBoost
- 303-04A Fuel Charging and Controls
- 303-04B Fuel Charging and Controls - Turbocharger
- 303-05 Accessory Drive
- 303-06 Starting System
- 303-07 Engine Ignition
- 303-08 Engine Emmision Control
- 303-12 Intake Air Distribution and Filtering
- 303-13 Evaporative Emissions
- 303-14 Electronic Engine Controls
- 307-01 Automatic Transmission 10 Speed
- 307-02 Transmission Cooling 10 Speed
- 307-05 Automatic Transmission External Controls
- 308-07A Four-Wheel Drive Systems
- 308-07B Transfer Case
- 309-00 Exhaust System
- 310-00 Fuel System General Info
- 310-01 Fuel Tank and Lines 2.3l EcoBoost
- 310-02 Acceleration Control
- 413-00 Instrument Panel and Interior Switches Illumination
- 413-01 Instrumentation Messages Chimes
- 413-06 Horn
- 413-09 Warning Chimes
- 413-13A Parking Aid
- 413-13B Parking Aid Vehicles with Parking Camera
- 414-00 Charging System General Info
- 414-01 Battery, Mounting and Cables
- 414-02 Generator and Regulator
- 414-05 Voltage Converter-Inverter
- 415-00A Information and Entertainment System - AM-FM
- 415-00B Information and Entertainment System - Sync 3
- 417-01 Exterior Lighting
- 417-02 Interior Lighting
- 417-04 Daytime Running Lamps (DRL)
- 418-00 Electrical Distribution
- 418-01 Module Configuration
- 419-01A Perimeter Anti-Theft Alarm
- 419-01B Passive Anti-Theft System (PATS)
- 419-01C Passive Anti-Theft System (PATS) Keyless Entry
- 501-00 Body System General Info
- 501-02 Front End Body Panels
- 501-03 Body Closers
- 501-04 Pickup Bed and Platform Body
- 501-05 Interior Trim and Ornamentation
- 501-08 Exterior Trim and Ornamentation
- 501-12 Instrument Panel and Console
- 501-14 Handles Locks Latches Entry
- 501-16 Wipers and Washers
- 501-19 Bumpers
