- First Name
- Dave
- Joined
- Jul 25, 2019
- Threads
- 342
- Messages
- 27,112
- Reaction score
- 137,225
- Location
- Back Home In AZ!
- Vehicle(s)
- 2023 Ford Ranger Tremor
- Occupation
- Retired...Full Time Slacker
Just curios but why not just use the Fuelly app for this? You can input all the same info there and it calculates everything for you and shows all your info on the main screen.This is a lot of nonsense really. I absolutely trust my own math over the ECM and computer itself.
I've been calculating mileage on all my vehicles by hand since 2006. It all depends on how accurate you input your data. if you use the full cost (which has a 9/10 cent cost in most of the US, that is $3.00 is really $3.009/gal), as well as using the smallest measurement you can (thousandths of a gallon, and tenths of a mile), you get very very accurate mileage representations which will very rarely match the computer mileage. Every vehicle I've ever driven has been a bit generous in its calculations. You cannot use more gas than you put in, and you cannot go a different distance than your odometer says (not accounting for tire size or different differences/etc that affect the readings). The "gotcha" to this is that you use the same method to fill your vehicle to help account for variances in temperatures/etc (filling until it clicks, wait 30 seconds, fill again until it clicks and then stop), using the same station/pump as much as possible to account for small variances in pump calculations (weight and measures validations in the states should (and will) catch any egregious dispensing errors that would have a meaningful impact on your numbers).
This is what I was using for my Mustang which gave me tenth of a mile readings for my odometer and trip (which the Ranger strangely doesn't give in either, only whole numbers):
With my Ranger, I haven't driven much before I shattered my ankle and haven't been able to drive, but the story is roughly the same:
Ultimately, if you're consistent with your fueling process as well as your recording process (regardless if your spreadsheet is rounding, which it could be while still using "proper" accurate numbers in calculations), you will always have more accurate readings than the computer is currently set to, especially since there's a variable that can be altered to change the way the ECU calculates the mileage display ( https://www.ranger5g.com/forum/threads/fuel-calculator-adjustment.2996/#post-38732 ).
