2019 Ranger MPGs
Bud
Bud
Rio Vista, CA
2019 Ranger XL supper cab 2019 Volt 99 XK8 Jaguar
Sailor
I averaged 23 mpg on my first tank, and half way thru the second tank and the dash shows 24.3. The truck has under 600 miles on the odometer. I live in a rural area, that is noted for its wind. Driving into the wind does make a difference. I am also old and no longer have a heavy foot.
Yesterday I filled the truck with gas, regular, in a town 25 miles from my home. The engine was warm when I reset the trip, and the driving included some town, but mostly on a two lane road. Speeds varied from 50 mph to 65 mph. This two lane road has very little passing areas, and the traffic was heavy enough that passing was impossible. When I pulled into my driveway the MPG on the truck display read 29.8. It actually was over 30, but driving thru our complex to the house dropped it a little. The truck tires have 44 pounds cold, that what it had in it when I picked it up from the dealer. It is a little bouncy, but I do like the mileage. The truck now has just over 850 miles on it.
ausable
Fred
2019 Ford Ranger, 2018 F-150
That air pressure is shipping pressure from the factory for the trains/haul away trucks. The dealer is supposed to deflate those tires to a more reasonable 30-36 cold psi. My lumbar simply couldn't withstand 44 cold psi. No sir.
John Lyman
Atlanta, GA
2019 Ranger Sport 4x2 Oxford White
I've had my Ranger for a week and half and I drive in metro Atlanta and the computer is saying 19.7 mixed. One of the joys coming from a Jeep to a Ranger that looks like good MPG. I must say I can see myself bringing that down using the sport mode - which is more fun - I can just skip going to the movies....
chuck stein
chuck
someplace close by
Tacoma-now-gone
Wow, long thread. Those MPG's are no better than a 1985 Chevy S10. Yes, 35yrs later, all new input controls, turbo's are back, better fuels, and yet 1985 still beats it in terms of MPG's. I suspect nobody is serious about how many MPG's a piston/gasoline vehicle is getting?
apotocki
Alan
Rochester Hills, Michigan
2019 Ranger XLT
Network Force Analyst
Is that with a side, tail, or head wind? 22 seems like you have more head wind during your travels.
First 350 miles on my XLT with factory AT tires is 20.3.....combination city and highway. Not sure if thats good or bad. Kinda was hoping for a bit better.
apotocki
Alan
2019 Ranger XLT
Oh, forgot to add pressure is 38 all around
chuck stein
chuck
someplace close by
Tacoma-now-gone
Use the highest octane gas you can, and go +3-5psi (cold) higher in tires than door label.
It's a small motor with a small turbo, and it's still not making good power until way out in RPM's. To get really good mpg's you need to accelerate slowly and cruise w/o AC on.
Side note - some tires will present for road surface drag if the PSI is too high. For these Ranger AT tires I really do not know what the optimal pressure would be for you to get max mpg's.
Fixing a spelling mistake on "ranger", Ford is supposed to have a "baby Bronco", does that mean they'll also have a Ranget?
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
People are very serious.
You're also comparing a 2019 Ford Ranger that has 270hp and 310ftlbs of torque, weighing ~4500lbs depending on config to a vehicle that had 62-110hp (diesel I4 vs I4 vs V6) and weighed ~3klbs.
The Ranger has 2-4x the power and nearly 50% more weight, and turns out roughly the same mileage, while also heavily increasing the emissions standards and putting out less chemicals per gallon burned than the S-10 did. It's easy to do this comparison of only one metric across 35 years, but it's not a meaningful comparison.
Dokkenmire
United States
2019 Ranger Xlt Sport Supercrew 2wd
If it's cold where you're at I wouldn't think that's too bad for break-in mpg. Either way it should slightly improve with more miles, mine did.
Mine too. I noticed it was getting better after 1000 miles were on it.
chuck stein
chuck
someplace close by
Tacoma-now-gone
I would argue that the weight is not significant factor when it comes to the standards used to measure mpg's. Aerodynamics is significant, and perhaps contact road friction. 1985 S10 and Ranger don't have significant diff in either of those two areas.
The emissions argument is both relevant and not relevant. Yes, per vehicle emissions are down, but global usage of such vehicles makes overall emissions greater. So it is safe to say technology is not keeping pace with the emissions issue from a practical application perspective. The "vehicle" view is not a good way to look at the problem, because if it was we would all be arguing "what global vehicle pollution issue" because every new vehicle is way better than it was in the past. Or in simple terms, really no great advancements with internal combustion engines. Didn't VW get stung with their BS claim around "clean diesel technology", thanks/credits to CARB in CA for busting them liars.
apotocki
Alan
2019 Ranger XLT
Thanks....yes, I am in Michigan so its cold. I’ve been babying it and not driving like I normally do - lol. I’ll be hopeful it improves after some more miles. Hmmmm. I may try increasing psi after this tank 3-4lbs and see what happens.
