2019 Ford Ranger OEM Splash Guards
CoastieN70
Travelers Rest, SC
2019 Ranger Lariet
Well after much searching and deliberation I pulled the trigger on the OEM Ford Molded Splash Guards.
To someone with minimal mechanical aptitude and or experience they can be overwhelming, especially with the "piss poor" directions given.
Let me assure y'all, the hardest parts of installing these are getting over the fear of drilling into a brand new vehicle and making sure that the Splash Guards are tight against the body (not bodybuilder tight just held in position tight), a third hand, Friend/Significant Other, can be helpful but not entirely necessary.
Effort to do the actual drilling is almost nothing so don't go all Dwayne "The Rock" Johnson on that drill.
The clips are the hardest part of the install, finesse and "semi The Rock strength" is necessary here, I used the flat side if a CLOSED pocket knife as a thumb-saver.
Whole install took 30 minutes at "Old Guy" pace so you Young Bucks can do it as fast or faster, just keep your testosterone in check...
chasvs
Tampa
Yup, That about describes my experieince as well! I would suggest that the best sequence to do the install is to attach the Clips First, which holds the Splash Guards in place while you drill the holes for the new screws. Then install the screws until snug. It's going into the plastic wheel arch trim so no need for over torqueing them!
BcP28
Bennett
2021 Ford F150, 2015 Ford Edge Sport
I realize most of this thread discussion is with the plastic molded splash guards, but here's another Ford alternative if anyone wants to see how they look. These are the "Premium Flat w/o Bright Accent" splash guards. They are nice heavy rubber and have the Ford Logo stamped/molded on them.
Front part number is: KB3Z16A550J ($60 at local dealership with Ford Employee discount)
Rear part number is: CL3Z16A550S ($73, same as above)
These are more of a 'universal' type flap. The fronts are cut to fit the wheel well in the Ranger, but the rears are pretty much a generic universal - in fact the instructions (which were more or less worthless) had different sections to install them on various generations of F150s and Super-Duties in addition to the Ranger. Installation was pretty straight forward, and the flaps included all the hardware needed for install . Overall I'm pretty satisfied with them and think they look good.
DBaz
Dan
'19 Ford Ranger Lariat FX4
For those cautious about drilling into their painted wheel arches, you might consider they're going to get thrashed anyway if you drive on dirt or gravel without splash guards.
Floyd
illinois
Plastic will crack a lot faster in cold weather.
It's a good choice for those who live in tropical places...I presume.
I have never had a Ford splash guard crack and I have bought them for decades.
Of course I live in tropical Chicagoland where it seldom gets more than 20° below zero. Fahrenheit.
David Schuster
NW Indiana
2019 Ranger XLT Sport 4x4; 1969 Torino GT
Picked up a set at a dealer that had them in stock. As others have noted, the directions look pi**poor. As far as drilling the wheel arches, is wheel/tire removal required to get a good angle? Maybe a 90 deg drive drill? Thanks...
DBaz
Dan
There was enough clearance in the back. For the front I just turned the wheels.
I was going to use my Dewalt 90 degree drive, but the problem was the length of the drill bits. I need to get some short ones.
I love mine as well...my install experience was quick and easy requiring only a 1/4 drill bit and a small hammer to tap the metal clips on...
2.7EcoBoost
NY
2019 Ranger FX4 Screw
BcP28,
I kicked around the idea of getting those. I ended up getting the factory molded because of the cheaper price. I am very happy with the molded guards, but those flat ones look great on your truck! You won't see many Rangers with them either, which is cool IMHO.
Rp930
Denver
Caved in and ordered Ford Splash Guards the molded ones. Just couldn’t face a rock road without them.
Hope they look ok. The pics above look good.
Update - installed today. Look great. Highly recommended.
Ranger Danger
East Coast USA
2023 Ranger FX-4 Off-Road BLK PKG Cactus Gray
Stay at home puppy daddy
I like these best, having had the hard plastic & rubber flaps on various trucks. How was the install?
BcP28
Bennett
Install wasn't bad. A little more effort to make sure they are squared up properly, and they did require drilling, but I'd say it took me less than 2 hours to do all 4 corners.
Ranger Danger
East Coast USA
Thank you, that was what I was looking for, drill or not to drill thank you again!
Rp930
Denver
Piece of cake. Just drill. You’re only drilling into plastic. I have the original moulded ones and they fit great. I don’t notice them which is what I wanted.
tivct
Dearborn, MI
Tremor, Focus RS
Just got a set of these in. The instructions are ridiculously useless. It’s like “mark with pencil, hit with hammer, look at it twice, repeat on other side.” Okay... thanks
Did you pull the fender trim off and drill underneath, then drill the trim at the same location? It’s so confusing.
