2.3l ford performance engine.
Winsonna
Winsonna
Nick
2022 ford ranger
It’s not the same pattern and the wastegate is a problem.
why would you reduce compression? It’s not going to help anything. More boost and timing with lower compression is similar to less boost and timing on higher compression, it’s a more efficient engine with higher compression.
Reduce the potential for detonation and a cooler air fuel and more power om pump gas. And if I try out the cylinder support system I'll need oversized pistons anyways. The only oversized pistons I see out there are for the mustang and it runs a 9.5 ratio
Loweredon33s
Baltimore
2021 Ranger
Performance person
I disagree completely, but whatever makes you happy I guess.
Also why would anyone need to bore to use a deck support anyway? Go ahead and bore a stock sleeve and see how long it lasts.
SICKQK
NY State
www.saddlebrookcontrols.com
2020 Ford Ranger XLT Crew Cab FX4
Automation Applications Engineer
I’m already well over 350whp on my stock engine. I’m looking for around 400/420 to the wheels then I’m done pushing the stock engine. I know it can make more than that but it’s not going to last very long without breaking something. If mine pops I might consider a few more upgrades, I really feel like sleeves or at least a deck support would be the way to go for more reliable power handling.
Might be better off seeing if a 2.7 can be made to fit. They can make very good power.
Loweredon33s
Baltimore
2021 Ranger
Performance person
Sure.
I will be happy with stock 2.3 and 400 to the wheels. Especially over a heavy iron block 2.7 and it’s associated problems
Winsonna
Winsonna
Nick
2022 ford ranger
Sure.
hopefully not out of the realm of possibilities, but id like that juicy 500 mark, maybe. im kinda like a fart in a whirlwind. just the other day i was 2 steps away from buying a 1972 ford escort mk1.
