Oil pan issue - broken fin near plug
Hulk337
Jon
USA
Ford Ranger 2022
Hi All, So the oil pan plug was on super tight from the dealers last oil change. I figured I would do this one and had to use a breaker bar to get it loose. Before I used that I tried a large crescent wrench and it slipped a little and a piece of the oil pan, looks like a fin or casting residual broke off very easily. I'm hoping this isn't a big deal. I drove 10 miles at highway speed after and nothing is leaking. Here are some picture. What do you all think? Is this a problem?
Thanks!
It was most likely way over torqued as if I recall it should be 20 ft lbs , would have to verify , the fin luckily appears to be only cosmetic damage from the wrench and is a clean fresh - break.
Hulk337
Hulk337
Jon
USA
Ford Ranger 2022
Thanks! So, only cosmetic? Should I JB weld it so stress cracks slow development?
21rangerCactus
Self employed
I wouldn't say it "broke off very easily"
More like you used the wrong tool for the job and banged it pretty hard.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I would take a dremel and just smooth it out being careful to not eat into the pan but only what is left of the fin. Just to make it look a little better.
That being said....
Won't hurt a thing to leave it.
Hulk337
Hulk337
Jon
USA
Ford Ranger 2022
Yes - it was my bad, wasn't thinking wrench would slip, that's how tight the plug was, did this with my old Hondas many times. I'm used to steel/iron so wasn't expecting the brittleness, like working on an aircraft engine I imagine.
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
Just next time use the deep socket or box end wrench.... either should minimize the likelihood of damage even if they slip off the plug... or just use a 3/4" impact...:crackup::crackup::crackup:
fob63
bill
Springdale Arkansas
2019 ranger
If you have the old piece. Clean and apply alum-bond. Sand to match after cure.
Seen this stuff used on hulls of aluminum boats to smooth out deep scratches then sanded. It hold very well.
Hulk337
Hulk337
Jon
USA
Ford Ranger 2022
Thanks for the info, yes I have it, I'll try this!
