Yellow Lariat LED Bulbs?
spike36ff
Pennsylvania
2019 Ford Ranger Lariat
All,
Does anyone know if they make a yellow bulb for the Lariat’s LED fog lights? Thanks
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
The LEDs in the headlights and fog lights are non serviceable. You could upgrade to something like this or throw some yellow film over them.
spike36ff
spike36ff
Pennsylvania
Ok thanks. Are those ones you linked a direct replacement for the factory? Or is there modifications needed?
cfhgarza
Ohio
They come with a bracket so you can use the factory mounting location without modification. Also include the wire harness adapter. I'm 90% sure they work with a Lariat but double check with stage 3 before.
Will be pretty similar if not identical to this install.
AutobotXJ
Ray
Volcano, HI
2020 Ford Ranger
Wildlife Biologist
I used laminex film- clear for my headlights and amber for my fogs. I like the look. I bought it because i want my headlights to be protected from debris.
spike36ff
spike36ff
Pennsylvania
Did you remove your fogs to apply the film?
AutobotXJ
Ray
Volcano, HI
2020 Ford Ranger
Wildlife Biologist
No, I was able to insert part of it under the plastic cover And work my way around. It’s is recommended you use a heat gun or hair dryer to make the flat sheeting conform to a rounded surface.
spike36ff
spike36ff
Pennsylvania
Gotcha
Ninong
Tacoma
2020 Ford Ranger Lariat/Velociraptor
Got these from Diode Dynamics, they are the Elite Series and come in clear or yellow. Performance far surpasses OEM, and they are a direct bolt in and plug and play option. Highly recommend.
