XL/XLT halogen to LED/HID upgrades
DHMag
Dale
San Antonio, TX
I figured we could maybe get a thread going to compile everyone's LED/HID upgrades from halogen.
I found a website, bulbfacts.com that reviews all kinds of lighting upgrades from Amazon. From his information, I bought the Hikari Ultra LED kit.
Here are the results:
Stock halogens:
I didn't want something that would create too much glare but I did want some more foreground light with a little more light at the edge.
The only downfall is that the covers will not fully seat because the fan motor is so big. They can be partially installed to keep dust and water out for the most part.
I would recommend the Hikari Ultra kit.
Dgm3306
Daniel
Pomfret CT
2019 Ford Ranger XLT FX4
Registered Respiratory Therapist
I purchased:
H11 LED Headlight Bulbs Mini Sized 80W 16,000LM Per Pair High Bright, AUXITO H11/H8/H9 Headlight LED Bulb Conversion Kit with Cooling Fan, 6500K Xenon White, Pack of 2 https://www.amazon.com/dp/B07WD6G42D/ref=cm_sw_r_cp_apa_i_eR.MDbJPCXX1X
And
9005 LED Headlight Bulbs Mini Sized CanBus Ready 80W 16,000LM/Pair Extremely Bright, AUXITO 9005(HB3) Headlight LED Bulb Conversion Kit, 6500K Xenon White, Pack of 2 https://www.amazon.com/dp/B07WCSJQYC/ref=cm_sw_r_cp_apa_i_FR.MDbFX3WS87
They both have the resistors built in and can easily be tucked into the headlight compartment and the dust covers fit on both the low and high beam bulbs without any issues.
I didn't really have to do any adjusting of the bulbs aside from lowering the low beams a little but the beam pattern is pretty good and it's a nice bright light.
DavidR
Eastern CA
2019 Ranger XLT Supercab Saber FX4
I was going to go with the Diode Dynamics lamps, but they have a lot of fitment problems in the new Ranger and they have taken them off their Ranger page for now. They are working on an updated version for cars that have fitment problems. Instead I went with the Hikari Ultras and am happy with them so far. I've also had them on our old Ranger for about a year with no problems.
EDIT: I also ordered a set of these to replace the hard dust covers that don't fit back on, but haven't had time to try them out yet:
https://www.amazon.com/gp/product/B076Q9D52Z/
Stock halogens:
I_smell_like_diesel
Western Maine
2019 Ford Ranger FX4 Lariat
Self Employed
I used Morimoto 2 Strokes 2.0's in my 2016 Fusion, I had owned before my ranger. I liked them a lot. Tried Diode Dynamics before the Morimotos and had very bad fitment issues and 2 bulb failures in 2 months. I wouldn't recommend running HIDs unless you're going to do a projector retrofit. I good quality LED bulb set should work well without too much glare.
SuperM
Mario
San Diego
I went with the Headlight Revolution recommended GTR Led. A liite difficulty during the install on the passenger side. Inhad to lower the beams. But does anyone know how to adjust horizontal alignment? My passenger light pattern is a little too far out.
I purchased:
And
So as much as you are trying your comparison is invalid. Open field vs a garage door show no difference beside light color
No horizontal adjustment only vertical. Are the bulbs adjustable for clocking? Clocking them so the LEDs are at 3:00 and 9:00 may help
SuperM
Mario
San Diego
I will double check. But Im pretty sire the base only fits 1 way.
Yes the base only fits the housing one way. The bulbs themselves may need to be adjusted. Not sure about the ones you have but so.e are adjustable so the LEDs face the right way when installed. It is called clocking.
Deleted member 1486
I just got a 21 ranger XLT. was wondering if any of you see a difference in distance and if glare is minimal? i am hoping to get some feedback like you folks to make right decision.
If you want to go with LED lights that is totally okay as long as you have a projector housing. You don't really get extra distance with LED lights in the halogen housings as they don't reject that well. Also they cause against the other drivers regardless what others might want to think. I currently have projector headlights in my XLT and I can tell you right now I have much further beam than the reflector and I don't cause the glare to other drivers
Deleted member 1486
Exactly the response i need. hoping to find someone here who has the experience on road conditions
jflogerzi
Moreno Valley, CA
I would just go with a full head light replacement. These are the ones I am eyeing:
Ford Ranger AlphaRex LUXX Series Alpha Black LED Headlights
