When should I have the transmission filter and fluid changed on my 2019 Lariat?
Ric
Ric
San Bernardino, CA
Honda Accord
I’ve look at maintenance schedule and it does not give a mileage point to change the transmission filter and fluid. When should this be done and what should I expect this to cost at a ford dealership? Thanks in advance for your advice.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Opinions will vary.
Ford calls for a 150k change. In my opinion that is WAY too long to go.
I use a much more agressive schedule, but for someone wanting to do something more resonable.
Drain and fill at 30k
New filter and fill at 60k
Repeat.
And no, I don't believe Ford knows best.
Ford knows what will get them out of warranty with 'the lowest cost of ownership'
These 10R80's are complicated beasts, yes they use a good filter and yes the ULV fluid is a stout fluid....that doesn't doesn't mean there aren't a ton of seals in the trans that can use refreshed additives, that doesn't mean there still aren't wear particles floating around that are better out than in.
Bsthroop
Brian
New Mexico
2019 Lariat 4x2 Sport
Broadband/ Microwave Engineer
See post #2 above, here is the maintenance schedule from Ford
sandog
Arizona
2019 Ranger XLT Crew Cab Hot Pepper
My '19 has 42K now. I was planning on waiting until 50K to do the drain, filter change and new fluid.
I was going to toss the plastic pan and get the aluminum PPE one.
I've had a couple rough shifts the last few weeks so might end up doing the service sooner.
It could just be that the fluid level is getting low.
I can't imagine driving to 150K before a service, but many do just that.
I haven't priced what the dealer would charge, I'll do the work myself like I did with my F-150 and Escape.
lou5560
Louis
New Jersey
2019 Ford Ranger XLT FX4 Off Road
I replaced mine at 49,000 miles. I personally would not wait 150,000. The dealership that did mine yesterday said the fluid was black. I used to work for a Ford dealer & I'm big on maintenance. You can never change fluids too early. Good preventive maintenance. I like to do mine between 30,000 & 50,000. It may be overkill but it's always good having fresh clean fluid. I also change my motor oil every 5,000 miles full synthetic.
Old Red Replacement
Ernie
Crystal River,Fl
2020 Ranger XL 4x4
Retired OTR Diver/Maintenance Mechanic
Scroll down to see pictures of this done from another thread .
For your information
Its a pricey upgrade even if you diy, not impressed with OEM
pan, where they put 19 mm dipstick cover, and firewall access
grommet behind ABS brake module/piping.
PPE high capacity pan+ 1 1/2 Qts ULV fluid $339
Ford 10R80 filter $40
Pan gasket just in case not used $40
Filter seal $2.50
ULV fluid $7 Qt
12V fluid pump $26
tax and shipping on some item depending on source, shop
Amazon, stage3Motorsport, Carid., goggle search each item and go from there.
IMO, if you can change your own oil, you have enough skill to
drop pan, R & R filter, install new or your plastic pan.
good luck, do not over tighten 8 mm & 13 mm stud bolts, the filter O ring, and pan are reusable at least once.
https://www.ranger5g.com/forum/threads/installed-ppe-transmission-pan.16182/page-5
Filter seal $2.50
ULV fluid $7 Qt
12V fluid pump $26
Planning on the PPE pan swap in the future, around 12-15,ooo miles.
Followed your posts about the swap, and I plan on doing it in the garage...
Question...since I do not plan on ever swapping the OE pan back, I think I'm just gonna drill a 1 inch hole in the low area of the plastic pan to drain fluid...should get almost all out, and saves me from having to buy a pump....
Sound OK ?
JasonTremor
2021 Ranger Tremor XLT
If the fluid was that dark, did they tell you how much debris was stuck to the magnet in the bottom of the transmission pan?
I'd probably be looking for an extended warranty asap given what you noted the dealership told you. I've changed a lot of transmission fluid over the years and never encountered dark fluid in something with just 50k miles on it.
dtech
colorado
I'd ask them to show me the fluid, being the mistrustful type, or make it a youtube vid of it like the jello engine oil.
BassRanger
Al
Oklahoma
Goodyear
Mercon LV/ULV starts to darken after a few heat cycles. That's why there's no color chart for the newer low viscosity fluids. Dark ULV doesn't mean it's bad.
Old Red Replacement
Ernie
Crystal River,Fl
2020 Ranger XL 4x4
Sound OK ?
Don’t see any problem with that, expect +5 Qts to come out.
Dereku
Chicagoland Area
Opinions will vary.
Repeat.
I do the exact same thing. I have done it for all my vehicles. I mean I do not have transmissions rebuilt and I treat them poorly at time so it works for me.
ctechbob
Shawn
Adult Daycare
To be fair, the 30k thing isn't what I actually do, I'm far more aggressive. I just feel 30k drain and fills are reasonable.
I vacuum out the pan, which is usually about 4-5 qts, and refill every 10k. So I change a little less fluid more often.
When I finally do the ppe shallow pan I will probably go to 20k drain/fill since I'll be getting more out.
Canadian Ranger
New Brunswick Canada
I bought my '19 Ranger in March with 30k on it. Changed all the driveline fluids the week I bought it. Judging from the amount of metal dust in both diffs, transfer case, and transmission, I'd say change them all at 2000 then 5000, then start listening to what the owners manual says.
