Weird noise while under throttle (Video Link Attached)
BFuller31
Idaho
My Ranger is making a strange noise only while under throttle, the second I let off the throttle the noise goes way. You can hear the noise immediately in the video and goes away when I let off the throttle only to come back. It has been at the dealership for about 2 weeks now. Wondering if anyone else has had a similar issue and if so what the fix was.
Any help is appreciated.
Are you (on and off) the gas pedal in the video, or does the sound do that (come and go) while on the throttle?
Where does the sound appear to originate from? - Engine Bay, Cabin, Rear End?
Has the dealer been diagnosing this issue for (2-weeks) or there for another issue?
BFuller31
BFuller31
Idaho
I am on the throttle in the beginning then off and back on. It appears to be coming from the engine bay. The dealer has not been able to find any issue.
21Blackout
Brian
Ny
21 Ranger
Warranty Administrator for FMC
is this a new to you vehicle? and is it the woosh/whistle sound you are concerned about?
BFuller31
BFuller31
Idaho
No, I bought it new and it has 31,000 miles on it. Noise just started happening.
StarLord
Matt
BC Canada
2019 Ranger XL STX FX4
go for a ride with the service advisor and get him to hear it as well.
Do you have to be driving (moving) for the noise to appear? or can you get it in park and rev the engine?
Fan clutch about to let loose?
21Blackout
Brian
Ny
21 Ranger
how is the air filter it sounds a lot like turbo spool on my cellphone not at home to get a good listen
BFuller31
BFuller31
Idaho
Air filter is new, it’s not a normal turbo sound. Sounds more like a bad bearing.
21Blackout
Brian
Ny
21 Ranger
hmmmm, I want to lean towards fan clutch but that should be able to be replicated at a stop in neutral or park,
BFuller31
BFuller31
Idaho
One would think so, I’ve tried to get it to replicate in neutral before with no luck. Only does it while driving.
