WeBoost install cab passthrough into bed
Heiserton
Logan
Missoula
www.3dproto-lab.com
2022 Lariat Ranger Tremor
Aviation
Tried to search for some info and couldn't really find anything for a double cab Ranger. I'm trying to find the best wiring route to go from the cab and into the bed for a WeBoost install. I did an install on my Maverick when I had it and it was cake, but the Lariat Tremor doesn't seem to have any noticeable passthrough spots. I can see that the bed has the passthroughs, but cant find the cab one. Anyone have any tips or suggestions?
Thanks!
Through the cab vent behind the rear seat...release the seat back and pull forward...the vent is slightly covered by the panel but if you put your hands into the cutout and up towards the right you'll feel the vents...you can then pass a fish wire through and catch it between the cab and bed...
Heiserton
Heiserton
Logan
Missoula
www.3dproto-lab.com
Aviation
That’s where I was thinking it was, but I think I was feeling down instead of up and to the right. I have the BO system, so the drivers side is covered with the amp and sub. Thanks for the confirmation!
RiverDog
Aaron
St Augustine, FL
2019 Ford Ranger XLT
Thanks!
What are you installing? I tried to look up WeBoost and it appears they do something with cell signal boosting but I'm not sure what that could entail for a truck bed. Just curious. :)
Heiserton
Heiserton
Logan
Missoula
www.3dproto-lab.com
Aviation
It’s a WeBoost Drive Reach OTR. Basically a cell booster. I had a smaller version in my maverick and it worked well, but the OTR version is a bit better for coverage with a larger antenna. Ideally you want to mount the antenna as far from the signal amplifier as possible, so I’m mounting the antenna to the T Track on my Go Fast Camper topper, but I need to be able to run the antenna cable from the cab and into the bed, or at least between the bed and the cab.
RiverDog
Aaron
St Augustine, FL
It’s a WeBoost Drive Reach OTR. Basically a cell booster. I had a smaller version in my maverick and it worked well, but the OTR version is a bit more better for coverage with a larger antenna. Ideally you want to mount the antenna as far from the signal amplifier as possible, so I’m mounting the antenna to the T Track on my Go Fast Camper topper, but I need to be able to run the antenna cable from the cab and into the bed, or at least between the bed and the cab.
Thanks for the info. Looks like a handy device to have! Good luck with the install.
Ranger_Rocks
Wandering
Wanderer
where can I get more of those cad drawings? I'm also trying to figure where all the wires in the tremor aux switches run to and colors
That diagram is from the Ford's Body Builder Layout Book.
Proper wiring diagrams will show Tremor aux switches.
