XL_Ranger_Danger
- First Name
- Matt
- Joined
- Mar 30, 2021
- Threads
- 4
- Messages
- 128
- Reaction score
- 391
- Location
- Huntington Beach, CA
- Vehicle(s)
- 2021 XL Ranger, (Previously 1976 Series III 109)
- Occupation
- Project Manager
- Thread starter
- #1
I decided do an install write-up for the WeBoost Drive Reach (cellular booster) after some inspiration from @charwest's overland build.
1. Mounting External Antenna:
Much like @charwest's build, I have a supercab XL; so rooftop real-estate is a hot commodity. I placed the external antenna on the rear leftward side of the cab since my internal antenna would be positioned in the middle on top of the dash near my phone.
2. Routing external antenna cable:
Per the instructions, the cable is strong enough to be wedged under the door weather seal. To keep the cable hidden, I wedged it under the interior door seal. Once at the floor the cable was routed under the cab floorboard until it was under the driver seat. To enable cable routing under the floorboard, removal of the driver rear stowage box trim is necessary. This allows enough of a gap to route the cable with relative ease.
3. Connecting external antenna cable to Booster Box (red shiny thing)
4. Connecting power supply:
Since my right plug is already taken up with my prior dash-mount wiring job (build here), I opted for the left plug. It was pretty easy to route the plug cable under the plastic center console trim. This hid it all the way to the booster module under the driver seat.
5. Wiring & Connecting internal antenna:
Per the instructions, the internal and external antenna should be as far apart as possible; while still allowing placement of the internal antenna in close proximity of your phone's location (within 8"). To balance the accessibility needs and distance requirement, I opted for wiring through the dash like my charging cables, utilizing a hole drilled prior.
Once the internal antenna cable was threaded through, dash was re-assembled and cable was tucked under the center console trim like the power cord. Excess was coiled up and tucked under the seat for a clean look.
Once wired up, check your booster unit to verify there are no blinking red lights (indicator of oscillation). If there are any blinking red lights, you'll need to increase the distance between your internal and external antenna.
