- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 98
- Messages
- 6,145
- Reaction score
- 8,298
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2019 Ford Ranger, 2019 cargo van, soon to be 1993
- Occupation
- Crown Forklift Technician
Soooooo...... Do yourself a favor and go back to the dealership and get the truck aligned. When you get it aligned ask them to allow you to be in the truck. This will be the "normal" load for the truck and will help toe be set correctly. I ran into this with my Ranger with the Old Man EMU lift.So, when I got my truck, I had a very slight, almost unnoticeable vibration at highway speed. To me, it seemed as if a tire was ever so slightly out of balance. I had the factory 18" wheels and tires rebalanced at the dealership and even though they stripped the weights and started fresh, said that they were spot on. Fast forward to about a two months ago, I purchased and installed brand new 17" fifteen52 wheels with 265/70 Falken Wildpeaks. Once installed, the vibration was accentuated so bad that it felt as if I was rolling around on ovals. I went ahead and installed hub-centric rings to match our bore spacing (106mm to 93mm) just to be sure. It may have been a placebo effect, but it felt as if the rings took out maybe 50% of the vibration. But the vibration is still there and it's still very noticeable. It was almost unbearable on a 500 mile trip my wife and I took on the interstate to Chicago. It definitely also feels like it's coming from the rear, although I can't tell if it's coming from one side or not. Also, it tends to smooth out some, then come back, smooth out, come back. I'm about to throw the factory wheels and tires back on, see if I can recreate the vibration and then take it to the dealership. I don't know if the larger tire size was making the original vibration worse or if it's a whole new issue, like a bad or out of round tire. I've had the new tires balanced 3 times by 3 different shops and they all said they were spot on. Has anybody experienced anything at all like this?
Hope this helps
