TSB 20-2277 2019-2020 Ranger - Shudder/Vibration When Accelerating From A Stop
TSB 20-2277 Poll
  • Total voters
    201
rdgallo
Ron
Morton, Illinois
The instructions for the TSB stipulate a half tank of gas.
I didn't know that. Mine goes in Wednesday and unfortunately will have a full gas tank.
Porpoise Hork
Bret
Houston
IT
As always, Phil, thanks for the information. We will see what the TSB does for mine. I am hoping for a fix, but am slightly skeptic. When you say, "PCM reflash" is the PCM the electronic brain for the tranny/engine? My truck's shifting behavior has never been what I call great. Some days are better than others. Mine seems like it will shift and then balks/surges right after the shift. I probably should have the dealer reflash mine also while it is in for the TSB. Again, thanks for your input.
The dealer likely won't reflash the PCM on yours since the TSB only lists the 2019 model year and yours is a 2020. I have the same issue (Nov 2019 build but badged 2020) and will probably end up having to live with it until Ford expands the current TSB or issues a new one to cover mine as well.
rdgallo
Ron
Morton, Illinois
I just read the TSB and don't see anywhere that says the fuel tank must be half full. Maybe my copy of the TSB has been revised?
rdgallo
Ron
Morton, Illinois
ChiefQM
Bill
Hiram, GA
2019 Ford Ranger XLT
You're right, it's not in the TSB. But I know I read it somewhere when I was researching the issues some of us are experiencing. Mea culpa.
Bret
Saint Augustine, FL.
2020 Ford Ranger Lariat 4x4 Off Road
Technical
mine is intermittent as well. the more i drive the less i notice it's there. colder temps make it more apparent too.
personally, i don't feel it is pinion angle or the carrier bearing but something with the torque converter.
This is "exactly" the issue. I am friends with a GM engineer. Of course his first sarcastic question to me was "Why did you buy a Ford?". Anyway, I have a 2020 Lariat with this "shudder" issue at around start to 35mph. Its annoying. Dealer did a transmission learn reset to no avail. I have since been running a Livernois tune which has helped quite a bit (I have it shifting through all the gears regardless, no skipping or gear hunting). That being said, when I mentioned it to my friend, he said "yep, GM had the exact same issue with their 8-speed transmission. Come to find out, it was the transmission fluid they were using. They did some testing, and the fix was to double flush the tranny, re-fill with a full synthetic fluid, problem resolved. Its the torque converter that is "flapping" constantly due to the cheaper fluid breakdown. He said eventually, the TV will fail due to the constant flapping. Now, not sure that is the issue here, but it makes perfect sense and feels EXACTLY like that. I'm just sayin.
Jfleming
Jfleming
Brecksville OH
2020 Ranger Lariat 4wd Supercab, 1996 Ranger XLT 2WD
Fireman
A co-worker of mine has a 2019 Colorado and had this shudder issue with the transmission. He took it back and they told him that they would change the fluid to fix it. This sounded hard to believe, but he swears that it did work on his Chevy.
I have no idea if this is the same issue some Rangers are having. The Colorado does not use the jointly developed GM / Ford 10 speed like the Ranger does.
This may just be two totally separate yet similar issues???
If it were a transmission issue, I would expect it would be a common complaint amongst a variety of vehicles (F-150, Explorer, etc as well as a bunch of GM vehicles). This exact same transmission is in a LOT of vehicles:
https://en.wikipedia.org/wiki/Ford-GM_10-speed_automatic_transmission#Applications
Porpoise Hork
Bret
Houston
IT
If I remember correctly the 10R80 10 speed transmission used in the Ranger was the product of a joint venture with Ford and GM. So if GM the issue was being caused by the trans fluid, I wonder how long Ford will take to come to the same conclusion. They have already been having serious issues with it in the Mustangs, (many of the known issues listed I have seen in mine or mentioned by others) so if the wrong fluid type is still being used or under filled it then it may just be a matter of time before similar issues start appearing in the Rangers and other vehicles that use it.
HarryD
Western MA
The stuttering issue that has been plaguing the Colorado ever since its last re-design is with their 8 Speed transmissions.
GM has been applying bandaid fixes for 5-6 years with fluid type, torque converters and different methods and equipment to flush the fluid.
This, and their use of their Engine Management System which shuts down engine cylinders for “economy” pretty much guaranteed I would not be buying one.
THANKFULLY, Ford released this new Ranger!!
jsphlynch
2019 Ford Ranger XL
I thought the issue with the Colorado was a stutter at shift points, whereas the Ranger problem is a general shuddering during acceleration even when not shifting?
On the other hand, if the Colorado does have the same problem as some of the Rangers, it's worth noting that a tailgate damper is standard on the Colorado. Coincidence?
Bret
Technical
That's correct. Ranger shudder is regardless of shifting. Its definitely the torque converter...has to be. Makes no sense to be anything else if its not actually shifting. All these new GDI engines are designed to provide torque at all speed ranges. No "lag". They use the transmission to do that. My buddy did mention the collaboration between Ford and GM on that tranny but he said that fell apart actually in the late stages. Not sure i'm quoting him correctly or not. I had a 2017 F-150 2.7 ecoboost with the 6spd tranny...no issues at all. My buddy bought the same exact truck only with the 10spd, shudder! The Mercon fluid Ford uses is, i believe, full synthetic, but, not sure a full flush and re-fill would solve anything...plus, at only 4500k on my truck they will think i'm crazy.
Bret
Technical
You think they would just put it on...WTF?
https://accessories.ford.com/damper-asy-12567.html
Porpoise Hork
Bret
Houston
IT
I have spent a bit of time reading the plethora of posts on the Mustang forum I linked earlier. It does seem that even as recently as August they are reporting 10R80 transmission fluid levels being between 1/2 and 1 1/2 quarts low. Multiple people are stating that once they topped the transmissions off to the correct level most of if not all of the issues they had been having were gone.
It's not too far outside the realm of possibility that our transmissions were also incorrectly filled at the factory. Looks like this needs to be investigated to confirm it is a more wide spread issue than just with the Mustangs.
