Truck bed cranes or truck bed winch with ramp?
Dustoff262
2020 Ford Ranger Lariat, black package
I have a very heavy generator to haul around from time to time. Instead of asking my neighbor to help lift it to the truck bed, Ive been searching for a solution that is simple and quick. I came across these two options. Basically would cost the same if I shop around. Approximately $320-350.
The first video is the Truck Crane. Looks like a lot of work, but can get the job done.
Maxxhaul Truck Crane assembly and review
The second is a winch in the truck bed. Hate to have to hardwire something and bolt on.
There are other truck bed cranes permanently attached and of course, instead of an electric winch, a simple 4 to 1 pulley system could work as well, but would look kind of cheap.
Muddy Fenders
Judd
Canada
I'd be skeptical the front bed frame could handle the pull from the winch over time.
Would rather mount it to the floor with a frame that attaches to solid structure.
The cranes are cumbersome, but effective.
I would second the comment about the winch attached to the bed - I'm sure it is not designed to take that much load.
I'm not sure if your thought is to take the crane with you somewhere to unload it or if you just need to do it all at home, but if it is the latter, another option (that also does double duty) is a car engine hoist. I've used that to load heavy things into my bed. The downside is that it is not very portable. A car hoist is basically exactly the same as the hoist in that video - it just has a different base.
Let us know what you come up with. This is an interesting challenge I think.
Dustoff262
Dustoff262
I thought about attaching a hoist to the ceiling using a 2x6 as its base lag bolted into the joists. I even saw this video but I do not have a tall ceiling and the garage door takes up a third of the ceiling space when open.
Dustoff262
Dustoff262
I should also add, that in all things, I look for double or even triple duty ways to solve a need that may arise in the future.
brroberts
Randy
Overbrook, KS
audio / semi retired
Not home, so no pics, but I have an aluminum range that works well and goes in any 2” receiver.
Jason B
2021 XL STX SE 4x2
machinist
Are you unloading the gen at your destination? If so, how are you doing that? Will you be taking the lift with you? If you leave the gen in the truck, consider a platform the same height as the bed to store the gen on. When you need to load it into that truck, roll in off the platform directly into the bed, no need for lifting.
Dustoff262
Dustoff262
I would need to drop it off for a few days, then pick it up and store it in the garage. Ive had help using a ramp. I just want something easier that I can do myself and can be of multipurpose use.
brroberts
Randy
Overbrook, KS
Ok, here’s what I bought in 2002.
Spritzlift aluminum hoist for 2” receiver.
brroberts
Randy
Overbrook, KS
My Ranger won’t run an inverter that can do what a 13.5K gen can. Mine has a eye just for lifting. System works well. I have some clean power Generac, but don’t remember the model.
brroberts
Randy
Overbrook, KS
It wasn’t in 2002. I have no idea in today’s dollars.
mtbikernate
NC
2019 Ranger XLT 4x4
I have a similar product I bought years ago called the Garage Gator. It's now owned by "Pro Slat" but I bought mine when Garage Gator was its own company.
garage gator 2 – Proslat US
The weight limit is 220lbs. Which is fine for bikes and other stuff like that, but it's not a lot otherwise.
