Transmission shifting
2TurboRanger
Jack
Oakley, Comiefornia
21 Ranger XLT 2.3 2x4 Wife Mine 24 Ranger Lariat 2.7 4x4
Retired Mechanic
This is my wifes 2021 xlt 2.3 She drives like grandma well she is one
I drive here truck and it is shifting bad . It has a big pause between shifts or even skips a gear
It has 30k
RangerBill
It has 30k
Skipping gears is normal in drive mode. It is programmed to do that. In sport mode, it doesn't skip gears.
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
that truck does not have a sport mode . Just tow haul It shifts the same in tow also
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
You might have that option with the Lariat This is a XLT
If you have manual shifting with the buttons. That is sport mode. And it should not skip gears in tow mode.
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
Shouldn't matter. Have you looked at the shifter to see?
Okay just went out and looked It does have a S I never looked.
I took it for a drive in S something is not right I takes off in 1st then goes in neutral won't shift for a long time Then shifts I come to a stop and it starts out in 3rd ? Even if I push the - button to 1st it is still in 3rd ?
RangerBill
Put in Sport mode without pushing any buttons. It should shift through all the gears automatically without skipping any gears.
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
I put it in S and no button pushing and I don't think there is a 2nd gear
RangerBill
If you push the + button, you will see a gear selection number highlighted on the dash. Using S mode, push the + button and look to see what gears the transmission is shifting into. Don't press the - button for this test. This will tell you what gears are being used.
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
Ok went out to drive it.
I shifted into S then pushed + the display showed 2 and it wanted to shift into 3rd and had a long delay . I stopped and
I put it in drive pushed + and display said 4 and it wants to leave in 4th push - it stayed in 4th i put it in park then drive still in 4th I turned off the motor restarted it now it's in 1st
ScarzRanger21(2.0)
Eric
Auberry, CA
Electrician
Mine does this in sport mode as well. If you switch from normal driving mode to sport and don’t press any buttons, it’ll upshift/downshift on its own. As soon as you start manually upshifting or downshifting gears with the +/- buttons, the truck stops shifting on its own.
If I’m in sport mode and manually shift to 2, it won’t upshift to 3 unless I press the + button. The truck thinks you want to shift yourself. To stop this, switch back to normal driving mode, then put it back into sport mode and don’t press any buttons. My truck and the wife’s truck do the same thing.
As far as hard or delayed shifting, THAT is a problem. If you don’t want to take it to a shop, you could try replacing the DPFE sensor, reset the adaptive learning, and see if it helps. If not, you might have transmission troubles. Hard/delayed shifting is usually the first sign that the 10r80 transmission is having problems. Being that it’s a 21, you probably don’t have the updated CDF drum. That didn’t start until 22. It’s a common problem with these transmissions.
