BHunted
- First Name
- John
- Joined
- Sep 26, 2019
- Threads
- 13
- Messages
- 615
- Reaction score
- 847
- Location
- Sumner County, TN
- Vehicle(s)
- 2019 Ford Ranger Lariat, 2019 Ford Mustang
- Occupation
- Retired
- Vehicle Showcase
- 1
- Thread starter
- #1
Thought I saw someone mention this but search didn't find anything. Weird. Went to get gas today. Went to start truck at station and everything froze. Every warning light came on. Brake wouldn't depress. Scary as hell. Waited a second and cursed a bit, then tried starting it again and OK.
Every warning came on and the dash looked like a Christmas tree. Any idea what the hell caused that?
Here is some of the log I pulled from ecm...
(OK) [13:13:56.849] Connection to adapter has been established on WiFi
(OK) [13:13:56.850] Adapter: ELM327 v1.4
(OK) [13:13:57.587] Connection to vehicle has been established
(OK) [13:13:59.101] Ford Ranger/Courier/Mazda B-Series EcoBoost Gasoline Turbocharged Direct Injection 2.3L 2019 ( 2019 MY ), VIN: 1FT*********53315
(OK) [13:13:59.354] PCM - Powertrain Control Module
(OK) [13:13:59.743] OBDII - On Board Diagnostic II
(OK) [13:14:01.083] APIM - Accessory Protocol Interface Module
(OK) [13:14:01.402] DCDC - DC to DC Converter Control Module
(WARN) [13:14:01.697] DTCs in DCDC: U0100:87-28
(OK) [13:14:01.701] PAM - Parking Aid Module
(WARN) [13:14:02.493] DTCs in PAM: U0100:00-28, U0101:00-28, U0557:00-28
(OK) [13:14:02.497] BdyCM - Body Control Module
(WARN) [13:14:03.214] DTCs in BdyCM: U0100:87-08, U0101:87-08
(OK) [13:14:03.219] SODR - Side Obstacle Detection Control Module - Right
(ERR) [13:14:14.534] SODR: Unable to read DTC
(OK) [13:14:14.535] SODL - Side Obstacle Detection Control Module - Left
(ERR) [13:14:16.721] SODL: Unable to read DTC
(OK) [13:14:16.722] FCIM - Front Controls Interface Module
(ERR) [13:14:18.949] FCIM: Unable to read DTC
(OK) [13:14:18.950] TRM - Trailer Module
(ERR) [13:14:21.182] TRM: Unable to read DTC
(OK) [13:14:21.183] DSP - (Audio) Digital Signal Processing Module
(ERR) [13:14:23.410] DSP: Unable to read DTC
(OK) [13:14:23.411] C-CM - Cruise-Control Module
(ERR) [13:14:25.609] C-CM: Unable to read DTC
(OK) [13:14:25.610] ABS - Antilock braking system
(ERR) [13:14:27.817] ABS: Unable to read DTC
(OK) [13:14:27.817] TCU - Telematic Control Unit Module
(ERR) [13:14:30.024] TCU: Unable to read DTC
(OK) [13:14:30.041] RTM - Radio Transceiver Module
(ERR) [13:14:32.228] RTM: Unable to read DTC
(OK) [13:14:32.276] RCM - Restraint Control Module
(ERR) [13:14:36.500] RCM: Unable to read DTC
(OK) [13:14:36.550] PSCM - Power Steering Control Module
(ERR) [13:14:38.724] PSCM: Unable to read DTC
(OK) [13:14:38.775] ACM - Audio Control Module
(ERR) [13:14:40.924] ACM: Unable to read DTC
(OK) [13:14:40.973] SCCM - Steering Column Control Module
(ERR) [13:14:43.103] SCCM: Unable to read DTC
(OK) [13:14:43.154] IPC - Instrument Panel Control Module
