Pinecrestjim
- First Name
- Jim
- Joined
- Oct 23, 2018
- Threads
- 4
- Messages
- 294
- Reaction score
- 173
- Location
- Pinecrest, FL
- Vehicle(s)
- 2019 Ranger, 2018 F-150, 2016 Escape
Big Blue, you are posting information that is contrary to what Ford states is the tongue weight. Their vehicle, they should know. From the previously referenced Towing Guide:
I quoted the entire paragraphs printed in the Towing Guide so that the information could not be picked apart or misconstrued.
Bottom line, as Grumpaw correctly clarified - WDH head is NOT part of the tongue weight calculation. The WDH head IS part of the payload calculation. Attachment bars mounted on the trailer tongue are a part of the tongue weight, the bars/springs are ~50% to tongue weight, and tongue weight is a part of the total payload calculation.
Trailer weight calculations can be confusing enough without spreading incorrect information.
Measuring Tongue Load With Commercial Scale. To measure actual tongue load or king pin weight, disconnect the trailer and place only the tongue (king pin) on a scale (at hitch ball or 5th-wheel king pin receiver height). If the tongue load/king pin weight exceeds the upper weight limit, move more of the trailer contents rearward to achieve the recommended tongue load/ king pin weight. If the tongue load or king pin weight is less than the lower limit, shift the load forward.
Note that this does not mention anything about the actual WDH being used to calculate tongue load. The WDH being included in the tongue weight is a misconception that many fail to differentiate. Then, further on the same page:Tongue Load or 5th-Wheel King Pin Weight is another critical measurement that must be made before towing. It refers to the amount of the trailer’s weight that presses down on the trailer hitch. Too much tongue load or king pin weight can cause suspension/drivetrain damage and can press the vehicle down in back causing the front wheels to lift to the point where traction, steering response and braking can be severely decreased. Too little tongue load or king pin weight can reduce rear-wheel traction and cause instability, which may result in tail wagging or jackknifing. Tongue load or king pin weights must meet the following requirements:*
For trailers up to 2,000 lbs., tongue load not to exceed 200 lbs. For conventional trailers over 2,000 lbs., tongue load is 10% of loaded trailer weight.
For 5th-wheel trailers, king pin weight 15% of loaded trailer weight.
Note: Be sure the addition of tongue load or king pin weight does not cause the key towing vehicle weight limits (GVWR and Rear GAWR) to be exceeded. Remember, GVWR and GAWR are found on the vehicle’s Safety Compliance Certification Label. If either of these limits is exceeded, you should go with a larger vehicle or a smaller trailer.
