Towing temperature and concerns
This is the space - that needs checked for leaves etc
Looks like yours needs to be cleaned as well
Borrowed pic - Image Search to highlight the area we are talking about (visual ref)
Stevedbvik1
2022 Ranger Tremor XLT
That space, especially the bottom 3-4” collects a lot of crap because of how the shrouding is designed. Both the front and back side of the radiator. The shroud is a two piece and the top half comes out really easy. That makes access to the back side easy to wash everything out. Whenever I have put some miles on involving off roading, water/mud or dirt roads I usually have to clean it out. It’s definitely an area you have to pay attention to. Here’s an image of what I washed out after my last off road trip. Bottom 2-3 inches were packed with this stuff. This was strictly from radiator
Cabose-1
Eli
Student
Grumpaw is right. I tow a 30ft 6k tt and temps go up bit nothing srious. I drive in tow mode and manual mode
I do not use 9th or 10th gear at all. Going up grades use 6 or 7th gear. I always keep rpms above 2thousand. The higher rpm keeps the turbo from working too hard, and fluids moving. Low rpm higher turbo boost and higher temps. That is my experience. As others have mentioned, not normal pulling something so small. Check cooling systems. Towing a trailer at 7k pounds, towing an suv, should not over heat you as well.
I tow heavy things regularly, so check what others have mentioned here.
Mustang2Ranger
Garrett
Southern California
OP - Intercooler and downpipe with high flow cat, higher flowing muffler if you don't already have it
Just gotta get the heat out
